Escort Cossie Wheel Studs
As per title im looking for some std ones for my car if anyone knows who sells them?
Also, with the Azev A's can i use the std wheel nut?
just asking because there was some serious damage to the studs when i removed the wheels yet the wheel nuts were tight
2 on each hub like this
No spacers but i will have a measure of the hole in the centre of the wheel tomorrow to double check they are sitting right.
I think they are ok though cos they were a right ba$tard to get off
Originally Posted by Doug
I got 4 brand new one's here just removed for long studs if your intrested Ł10 posted .
Regards Doug .
Regards Doug .
I think you will find that the Ford nuts have the wrong taper for most aftermarket wheels.
Paul,
Unfortunately I didn't have one of these in stock, so is coming direct from supplier.
The nuts are Ł1.45 each (which is same price as studs) and delivery is Ł10, as is quite heavy for 16 + any studs you might want...
Mike,
I'm just going to require the wheel nuts ATM as the local Ford Dealer has the studs in stock
I will send you an e-mail to confirm the order
Cheers,
Cheers,
Originally Posted by rstoughy
Mike,
Billy_RS
16
Oct 11, 2025 09:41 PM
