replacing 80 spec spoiler with 90 spec item... how?
Old Jul 31, 2004 | 12:14 PM
DanS's Avatar
DanS
Default replacing 80 spec spoiler with 90 spec item... how?
How do i remove my spoiler? Is it all done via the bolts under the caps or do I need to take bits of the understand of the tailgate apart to get to the bolts as well?
Cheers!
Dan
Old Jul 31, 2004 | 12:20 PM
cossie1's Avatar
cossie1
iirc there is 4 bolts under the caps and 1 in the centre (from inside)
but....
the 90 spec spolier is bolted in different places so you will need to clean to boot off propperly (as there will be a thick black line where it sat) and then redrill to boot lid for the 90 spec to fit.
Last 1 I changed i just swapped the bootlds over complete was soooo much less hastle
Old Jul 31, 2004 | 06:49 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
I never bothered with all that. Just fit the 2 rear screws and the 10mm nut from underneath. If the spoiler isnt bent at all it wont need the front screws.
If it is though just drill 2 small holes in the tailgate, and fit a couple of self tappers. Its not load bearing so as long as it cant be nicked, i'll be ok.
Old Jul 31, 2004 | 07:02 PM
CliffRS4's Avatar
CliffRS4
I did this on my old series 2 with my leg in plaster after an operation so you should have no problems.
Take the old spoiler off ( the screws might be rusted )
Put the 90 spec one on , locate it with the 2 bottom screws
Mark where you will have to drill holes in the higher holes
Take the spoiler off
Drill the holes
Put the spoiler back on
I used self tapping screws and secure it to the body work
This all sounds easy but should the screws be rotten beyond being able to undo them which mine were.
I didn't realise that there is a metal frame in the spoiler and cut V's above the screw locations taking chunks out of the spoiler till I could drill the screws out.
It was a pain in the arse but well worth it
Old Jul 31, 2004 | 07:03 PM
DanS's Avatar
DanS
Took a while longer as said above had to drill some new hols, but looks ok i recon... not a bad colour match either
Cya at ford fair if ya going!!
Old Jul 31, 2004 | 07:27 PM
Zetec Andy's Avatar
Zetec Andy
Old Jul 31, 2004 | 07:29 PM
Rich_w's Avatar
Rich_w
Looks nice.
Old Jul 31, 2004 | 08:12 PM
James Raby's Avatar
James Raby
Looks good, but I love your car anyway LOL
Great job
Old Aug 3, 2004 | 11:12 AM
DanS's Avatar
DanS
Great job
Thanks mate, wish mine was blue though
Old Aug 3, 2004 | 11:43 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Nice car, nice job - sorted!!
Old Aug 3, 2004 | 11:46 AM
keithG666's Avatar
keithG666
Originally Posted by Mr.Manchester
Old Aug 3, 2004 | 11:59 AM
Oranoco's Avatar
Oranoco
Job well done Dan mate
Old Aug 3, 2004 | 12:04 PM
McPikie's Avatar
McPikie
I want one, Sean with the 666 cossie was supposed to be looking for one for me but no joy yet.
Reckon I need a 90 spec bumper and trim as well
dirty-diesel
Oct 3, 2015 08:00 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Vincereese
Sep 17, 2015 10:34 AM
chris m1
Sep 7, 2015 08:02 PM
Adam Graham
Sep 6, 2015 06:04 AM
