been told this shouldnt be like this????
basically thinking of chopping the fiesta in for saph 2wd and the bloke had a look at my ecu and said that it shouldnt be running like it is. he reckons there should be something in the slot. is he right?????
thats what i thought, i ah been told it had been chipped but never looked to check, however matey boy who seems to know alot aid even though there is no chip in there it should still have a standard ford chip or plug in there
As standard it has a plate that covers it this is just to protect the chipboard. It probably has been chipped in the past and has been removed. When he says not running as it should what is it doing?
i think i didnt put that clearly enough, it does run very well, he said it shouldnt run at all, also i said that its hitting 12 psi( which i need to turn down) and he said thats not poss as standard chip only allows around 10 but its hitting about 12 then overboosting and cutting out
Originally Posted by fiestaturbo1984
is that the better of the 2?
Originally Posted by rsmcelroy
Mine is probably still quicker than yours even with my 'inferior' management!
in the next two weeks mine will have 195 chip, injector's which i have, t34 which is the size of a baby's head which i have , cossy fuel pump,
well whats the next best step tuning wise, thinking og going 195 chip and some beiges followed by trip to powers
T34! someones getting serious! are you getting George to do that for you? he will have fun putting that in
I am surprised he has not gone down that route yet he has done everything else. Its a tight squeeze with the T3 i dread to think what yours will be like!
i got a saff turbo collins -31 beiges t2 cam waitin to go on
just need a chip and uprated fuel pump
iv got a pace intercooler and rad already
wat sorta power will i get out of this? ball park figure
If you decide to chip it i have some biege injectors what would be open to offers
or if i was you i would buy a mega squirt system and run GREENS
but with all the other usual mods
You need to get a lap top off ebay ....... and they send you the links for the software to download when you buy it.
Kit can run everything boost control, anti-lag, 5th injector....an on and on.... it also has built in 3 bar map sensor
Loads of kit for the money
its what i'm getting next winter when the fiesta's off the road.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
muz
Sep 30, 2015 08:29 AM
rsguy
44
Sep 29, 2015 03:29 PM
