missing chassis no on floorpan, how legal?
Old Apr 3, 2006 | 06:36 PM
andre_k's Avatar
andre_k
Default missing chassis no on floorpan, how legal?
im considering a s2 shell, however the floor pan has been repaired, and has no vin no. next to the drivers seat as a result...
opinions please on legality etc
Old Apr 3, 2006 | 06:50 PM
charlie luciano's Avatar
charlie luciano
Default missing
Don't touch with a barge pole
C L
Old Apr 3, 2006 | 06:52 PM
David Ramsey's Avatar
David Ramsey
Why would anyone need to remove it in the first place.
As said above walk away
Old Apr 3, 2006 | 07:02 PM
Oranoco's Avatar
Oranoco
I wouldn't walk away
I'd fookin run
Old Apr 3, 2006 | 07:04 PM
abdr500's Avatar
abdr500
if its had a new floor pan fitted and ther wount be any floor numbers
Old Apr 3, 2006 | 07:05 PM
Shings's Avatar
Shings
Agreed, could be totally harmless... what you musn't do in this situation is scratch your own number in....
Old Apr 3, 2006 | 07:17 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
can get a stamp set for it,but if the floor peice and has been replaced,it aint a real problem!
Old Apr 3, 2006 | 07:25 PM
Alvyn's Avatar
Alvyn
as said above may have just had a replacement inner sill and floor pan!
Old Apr 3, 2006 | 07:26 PM
GUZZLER's Avatar
GUZZLER
lots of mk 4's used to rot where the rear of the front seats bolt in, a lot rot into the chassis number, if the rest of the car is kosha i wouldn't care to much.
Old Apr 3, 2006 | 07:28 PM
Shings's Avatar
Shings
Damn right... on my RS1600i I was gonna replace the whole floor.. never gave a thought to numbers
Old Apr 7, 2006 | 07:53 AM
SS1's Avatar
SS1
if the shell is restamped ie Q PLATE isnt it normally on the suspension strut on the drivers side
intresting i would like to know if any body here does
Old Apr 7, 2006 | 08:01 AM
Sheldy's Avatar
Sheldy
Once went to look at a shell with no numbers years ago which was described as being that way since it was bought as a bare shell from ford.
So really this would come under the same description would it not?
Old Apr 7, 2006 | 08:52 AM
SS1's Avatar
SS1
Sheldy
always a number some where
gambo08
Feb 4, 2016 10:49 PM
Fil
Sep 30, 2015 12:08 PM
Mark_
Sep 22, 2015 10:06 AM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
peter/jedi
Sep 15, 2015 03:01 PM
