wheel spacers
Old Apr 3, 2006 | 04:14 PM
JimRS's Avatar
JimRS
Default wheel spacers
are wheel spacers dodgy at all?
Old Apr 3, 2006 | 04:17 PM
Doug's Avatar
Doug
Depends what size your thinking of using and as long as the wheel still locates on the hub I dont personally see a problem but take in to consideration you have less stud to put the wheel nut on so the simple option for that is long studs
Regards Doug .
Old Apr 3, 2006 | 04:20 PM
JimRS's Avatar
JimRS
Regards Doug .
Thats another thing, know anywhere i can get longer studs?
Old Apr 3, 2006 | 04:21 PM
charlie luciano's Avatar
charlie luciano
Default Spacers
Had problems fitting big brakes in my saff and i'm using spacers, as long as the spacers used are hub centric and they sit on existing hub shouldn't cause any problems,
C L
Old Apr 3, 2006 | 04:33 PM
Mr Brannen's Avatar
Mr Brannen
I had 6mm on my saff and it was fine
Old Apr 3, 2006 | 04:35 PM
Liams's Avatar
Liams
Ive just put longer studs on my FRST, using 15mm on the back so had to use transit studs there just over 10mm longer!! But like charlie luciano said use decent spacers otherwise all the weight is on your four studs!!
Old Apr 3, 2006 | 04:48 PM
JimRS's Avatar
JimRS
any ideas where to get longer studs from?
Niall.b's Avatar
Niall.b
i just got a set from speed shack last week that are about 10 mm longer
Old Apr 3, 2006 | 04:50 PM
Liams's Avatar
Liams
Got mine from ford!
Old Apr 3, 2006 | 04:52 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Nowt wrong with them, especially if you use the ones that have replacment studs, ive seen competition cars running stacked spacers giving 60mm extra spacing etc.
Im running 20mm's on my GTR and either 20 or 30s on the SX, depending on the rims...
Old Apr 3, 2006 | 06:17 PM
SteveB's Avatar
SteveB
If you get a proper "hubcentric" kit they come with the longer studs..... failing that I got 15mm longer studs from Burton Power for £1 each + VAT
Old Apr 3, 2006 | 06:58 PM
markk's Avatar
markk
ive run them for years and had no probs, the only time you will have probs and snap the studs is if they come loose, will snap all studs in no time !
Old Apr 3, 2006 | 08:31 PM
SteveB's Avatar
SteveB
What I am using....
http://www.eibach.de/frame.inc.php?S...&LID2=7&LID3=0
ossie cossie
Sep 21, 2015 05:07 PM
cliffy70
Sep 20, 2015 09:18 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
povey@pembrokeshire
Wheels and Tyres
Sep 9, 2015 06:44 PM
Adam Graham
Sep 6, 2015 06:04 AM
