spray painter quick question
Old Apr 2, 2006 | 09:53 PM
xr4x4rs's Avatar
xr4x4rs
Default spray painter quick question
im in the middle of prepping my engine bay so i can paint it i will be using alll proper paint and gun etc
the only question is regarding the paint
its bayside blue ( nissan skyline ) code is tv-2
now its blue metallic but there is also a pearl which goes onto the mettallic
most people ive spoken too havnt heard much of a pearl going onto a mteallic as its usually flat colours
do i put the pearl on after the final coat of mettallic obviously leaving the base coat to dry for 10 mins first or wait until the vbase coat is completely dry leaving 24hrs
what about laquer after does the base coats need to be dry or tacky
any help would be great thanks
Old Apr 3, 2006 | 03:00 PM
RSNeil's Avatar
RSNeil
hi mate sounds like your using a 2 stage pearl. firstly apply your blue base coat until its covered, then when thats dry you apply the pearlcoat. As for the laquer just apply when the base colours are completley dry. ps make sure you use the correct shade of primer before applying the colours so the paint covers easy. hope this is of some help mate
Old Apr 3, 2006 | 03:51 PM
xr4x4rs's Avatar
xr4x4rs
thanks mate
wont be using primer for the engine bay just keying it up to accept the base coat the cars blue anyhow so hopefully shiuldnt make a difference
thanks much appriciated
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Fudgey
21
Sep 30, 2015 06:19 PM
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
