Straight cut gears
Old Apr 2, 2006 | 08:11 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Default Straight cut gears
whats the main reason for them? been told there better for track cars
and also whats the typical life span of them??
Cheers Radleigh
Old Apr 2, 2006 | 08:15 PM
Doug's Avatar
Doug
Default Re: Straight cut gears
Cheers Radleigh
Stronger less breakages but fooking noisey but you gotta love the sound
erm life span forever unless your an absolut animal
Old Apr 2, 2006 | 08:17 PM
Charlie Chalk
Unknown.
cool!
Looking into getting a straight cut T5 when im back, Not arsed about the noise either
Old Apr 2, 2006 | 08:19 PM
Dan's Avatar
Dan
Evening Dude, still thinking about the S2 all those miles away then!
Old Apr 2, 2006 | 08:23 PM
Charlie Chalk
Unknown.
damn right...
im having bits made up here too
Old Apr 2, 2006 | 08:25 PM
Dan's Avatar
Dan
Care to enlighten me, or is it another top secret MSN job!?
Old Apr 2, 2006 | 08:28 PM
gus's Avatar
gus
here we go again with the secret squirel again
Old Apr 2, 2006 | 08:32 PM
Dan's Avatar
Dan
Always the way aint it! A little beer mat shuffling here and there...
Old Apr 2, 2006 | 08:33 PM
Charlie Chalk
Unknown.
Old Apr 2, 2006 | 09:47 PM
GARETH T's Avatar
GARETH T
dont put any thrust loading onto the gearbox shafts/bearings
Old Apr 2, 2006 | 09:52 PM
NUTS RuS's Avatar
NUTS RuS
My 1st 2nd and 3rd gears generally last about 2 years before going in the bin....
Old Apr 3, 2006 | 10:08 PM
Charlie Chalk
Unknown.
what do you mean Gareth???
Cheers Tony
Old Apr 3, 2006 | 10:30 PM
ON-UJAH's Avatar
ON-UJAH
They are cut straight as opposed to angled, so when engaged, the forces work 90deg from the shafts against each other - there is no forces in the direction of the shafts. No axial forces...no thrust forces - I'm no engineer but I think those are the correct terms.
Old Apr 3, 2006 | 10:31 PM
GARETH T's Avatar
GARETH T
grab me on msn one day and ill chat too you about it,, well what i uderstand anyway
Old Apr 3, 2006 | 10:40 PM
Charlie Chalk
Unknown.
that wont be for 4 months then LOL
its 5 hours time difference, byt the time ive finished work, gym eaten showered.. its to late!
If you could, reckon you could drop me a pm
Cheers too!!!
Or do you know what ON-UJAH has just typed???
Cheers also
Old Apr 3, 2006 | 10:42 PM
rapidcossie's Avatar
rapidcossie
cool!
you really need to try a straight cut box first mate..
they are FAR too loud for the road and dont like shifting at anything aprt from full throttle..
would be a nightmare onthe road IMO
Old Apr 3, 2006 | 11:17 PM
markk's Avatar
markk
rapidcossie
not true that pal, they are as refined as a normal box. now if we are talking dog engagement then thats totaly differant m8
Old Apr 3, 2006 | 11:20 PM
rapidcossie
maybe got mixed up
thought the reason normal gear box's were helically(sic) cut was to ease engagement?
Old Apr 3, 2006 | 11:35 PM
dexterc's Avatar
dexterc
I thought noise was one of the issues with straight cut gears?
Old Apr 3, 2006 | 11:44 PM
NUTS RuS's Avatar
NUTS RuS
I cant hear any passengers speaking (and visa versa) unless we have the intercom or practice headsets on.
Even shouting at times it is just totally impossible to hear what they are screaming at / for, and the passenger is what.... about 20 inches away ?
Yes they are loud
Old Apr 4, 2006 | 12:23 AM
Main two reasons for straight cut gears:
1) Less side loadings, which means they can take higher loads without punching the shaft out the of the case etc (pulsars do that a lot on helicals for example)
2) MUCH cheaper to produce, especially in small numbers, so when you are racing and want loads of different ratios, you wouldnt be able to tool up for helicals even if you wanted to.
I only ever use straight cut cogs when helicals wont handle the power if its a roadcar.
Old Apr 4, 2006 | 12:30 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
So from what I see a straight cut gearbox would stop an animal like me from trashing it everyday when I slam between the gears on the redline!
Doubt it will save the 4th clutch in 2 years .......
Thats with 155bhp, fuck knows how I intend to keep a cossie clutch intact for more than 5 minutes if I convert my car to cossie power!
Old Apr 4, 2006 | 12:32 AM
You normally break the synchros doing that not the gears, so SC wouldnt make any difference unless its a bog dox or something too.
Old Apr 4, 2006 | 12:46 AM
Psycho Warren
Carbon Crazy
Is there a mechanical solution???
If so I presume its expensive!!!
Old Apr 4, 2006 | 01:02 AM
Warren, www.bsm.co.uk have the best solution for you by the sounds of it
Old Apr 4, 2006 | 01:13 AM
Psycho Warren
Carbon Crazy
Hey!!
I've not had any serious crashes in the last 2 years!!
Driving off the side of a mountain does not count as there was no damage!!
Old Apr 4, 2006 | 05:50 PM
Charlie Chalk
Unknown.
cool!
Its for my track car, so no issues there, cheers though
Cheers all for the replies
Old Apr 4, 2006 | 06:04 PM
Moonie's Avatar
Moonie
maybe got mixed up
All the forward gears are in constant mesh - they do not slide into each other to engage gears. Its the syncro hubs that lock the various gears to the shaft to produce drive.
Old Apr 4, 2006 | 06:27 PM
Jamz's Avatar
Jamz
http://www.supercarchallenge.nl/video/Assen-bmwSTW.wmv
Don't think I could cope with a straight cut box if it sounded like that
Old Apr 4, 2006 | 06:57 PM
markk's Avatar
markk
to be honoust that is the loudest box ive ever heard, i would actually say theres something wrong with it, because all the ones ive had, and all the cars ive been in with them non make the whirring noise that that makes - its fooke d! !
Old Apr 4, 2006 | 07:38 PM
ON-UJAH's Avatar
ON-UJAH
Most rally cars run straight cut dog engagement gears, also most productions cars have a straight cut reverse. So you can imagine what it would be like if you had to drive about with that whine all day.
You can also get helical dog engagement gears, so you can slam the gears in like a rally driver, but still have the low noise of an everyday box.
There's also a company in Japan that developed a gear shifter that you just push forewards or backwards to change up or down.
http://www.ikeya-f.co.jp
Old Apr 4, 2006 | 09:59 PM
NUTS RuS's Avatar
NUTS RuS
That sounds very similar to mine The whine sometimes actually hurts your ears
Its solidly mounted to the car everywhere with not a single rubber bush in sight, the noise transmits all too easily.
Old Apr 4, 2006 | 10:12 PM
markk's Avatar
markk
remind me never to thumb a lift from you , i thought mine was loud pal
Old Apr 4, 2006 | 10:25 PM
Psycho Warren
Carbon Crazy
Get an intercom and headsets!!!!
Old Apr 4, 2006 | 10:34 PM
markk's Avatar
markk
WOW - id never thought of that
Old Apr 4, 2006 | 10:39 PM
NUTS RuS's Avatar
NUTS RuS
Saves shouting at the drive through Mark
Old Apr 4, 2006 | 10:44 PM
Psycho Warren
Carbon Crazy
Youve still got to shout at the chav serving you, or switch off your engine!
Old Apr 4, 2006 | 10:57 PM
markk's Avatar
markk
lol
Old Apr 4, 2006 | 10:59 PM
NUTS RuS's Avatar
NUTS RuS
Where is that picture ?
Old Apr 4, 2006 | 11:09 PM
markk's Avatar
markk
this one tony ??
