Complete ICE system for sale
Complete stereo system for sale. Would like to sell the system whole but will split if the price is right.
Pioneer DEX-P99R Head Unit & 6 disc changer
The head unit was the top unit in the Pioneer range 3 years ago and would have cost over £600!!!
3 x 4v preouts (front, rear & subwoofer),
DSP (Digital Signal Processor) - allows you to change the frequencies that are sent to each channel for optimum performance,
Comes with 2 remotes (hand held & steering wheel),
Dot Matrix Display,
RDS, CD Text, removeable faceplate etc.
Comes with manual, installation manual & original warranty certificate.
4 Channel Kenwood KAC-PS500F Amplifier
This amp was the top of the range Kenwood 4 channel amp 3-4 years ago and would have cost around £500.
Can be run in 4, 3 or 2 channel modes,
75w per channel,
Comes with instruction booklet.
The Instruction booklet can be seen here
http://www.kenwoodeurope.com/languag...KAC-PS500F.pdf
Mono Channel Kenwood KAC-PS400M Amplifier
Ideal for running one or two subwoofers,
2 Ohms stable,
Rated at 600w @ 2Ohms,
Built in fans,
Comes with instruction booklet, which can be seen online here http://myweb.tiscali.co.uk/boogat/ps400m.pdf
Rockford Fossgate FNQ Component Speakers
2 x 6.5" mids & 1" tweeters,
Also come with genuine Rockford Fossgate Crossovers.
2 x 12" MTX ThunderPro Subwoofers + Box
Thunderpro 500w Speakers
Custom made box.
I also have a box full of all of the wires etc. that I removed when removing all of the above from my car. Including the following:
Rockford Fossgate inline fuse & holder
2 x RCA leads
Plenty of power wire of varying gauges
Alpine Dual Amp balancer (used in the above system to easily adjust the amount of bass)
All of the above has been used together and is in good/excellent condition. Due to the size and weight of the items it would have to be collected (i'm in Selby, N Yorks) OR I could bring it to TOTB3 if anyone is interested.
All in all this system is everything you need to make your car sound mega sweet! The sound was amazing in my car and used to impress everyone who I demonstrated it on.
I need the space so it all has to go, offers around £750 for the lot.
Dot Matrix Display,
75w per channel,
2 Ohms stable,
Built in fans,
Custom made box.
2 x RCA leads
Adam Graham
Sep 6, 2015 06:04 AM
