Does a cosworth support
Old Apr 1, 2006 | 09:19 PM
Doug's Avatar
Doug
Default Does a cosworth support
Does a cosworth support a veichle speed output from the pcm I understand that the speedo is mechanical i.e cable but could i fit an APEXI RSM and get a veichle speed from the ecu or even abs module ?
Regards Doug .
Old Apr 1, 2006 | 09:55 PM
Jim Galbally's Avatar
Jim Galbally
theres a VSS on normal sierras...
Old Apr 1, 2006 | 10:05 PM
markk's Avatar
markk
if you have a speedo cable i have a sensor that goes in the line to give an output to a trip meter if it will do the job, just gives a speed signal
Old Apr 1, 2006 | 10:41 PM
rsnissan's Avatar
rsnissan
you can use a stack wheel speed sensor or similar
Old Apr 2, 2006 | 09:11 AM
JjCoDeX75's Avatar
JjCoDeX75
Hi m8
I use a Blitz Boost Controller on my 2WD Cosworth, and I can confirm that the ECU does not have a speed sensor.
I got the speed sensor by taking a feed off one of the abs sensor wires (where it connects to the ECU). This is your best bet, though you may need to calibrate whatever you are connecting to the number of teeth on the wheel. Usually this can be done with high end equip using a self calib mode (ie you drive at 30mph and tell it that!)
I have a wiring diagram at home for the ABS. IF you want to knoe which one it is for a 2wd let me know.
JJ
Old Apr 2, 2006 | 09:27 AM
Doug's Avatar
Doug
Originally Posted by JjCoDeX75
Hi m8
JJ
You have pm
Old Apr 2, 2006 | 09:28 AM
Doug's Avatar
Doug
Mark you have pm buddy
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
