Boost Controllers.....
Old Apr 1, 2006 | 03:26 PM
Default Boost Controllers.....
...whats a good way of getting a stable boost pressure with no spike?Dont want air injectors or anything ECU controlled!
What incar boost controllers can you get that are good Jap style?
Old Apr 1, 2006 | 03:33 PM
Ginge !'s Avatar
Ginge !
just finding my feet
blitz id3 with matching power meter seem to work nice
Old Apr 1, 2006 | 03:42 PM
Link?
Old Apr 1, 2006 | 03:45 PM
Ginge !'s Avatar
Ginge !
erm,,,,,,,,,,,, i cant link as my work block search engines
look on ebay as there about 250 quid plus another 120 for the power meter,,,,,,,,,, that allows you to set a few boost limits against MPH,,,,,, so you wont have 42psi at 19mph ect
Old Apr 1, 2006 | 04:12 PM
Jamz's Avatar
Jamz
Greddy Profec B Spec II's are popular.
http://www.greddy.com/prod_profecb2.htm
Old Apr 1, 2006 | 04:18 PM
Ginge !'s Avatar
Ginge !
so are dump valves and neons
Old Apr 1, 2006 | 04:20 PM
GARETH T's Avatar
GARETH T
twin port actuator and a pressure regulator
Old Apr 1, 2006 | 04:23 PM
....yeah good point gareth...the julian godfey one i used before and had it in car was very good....but they do sell them for like 220 plus vat and i thought a jap controller would be a nice change...which one does rodney use?
Old Apr 1, 2006 | 04:25 PM
Stu @ M Developments's Avatar
PassionFords Creator
HKS EVC 5 Phil.
Old Apr 1, 2006 | 04:26 PM
GARETH T's Avatar
GARETH T
im sure rod uses an eboost
and if you want a twin port set-up, just buy the actuator, and then buy all the other bits from radiospare or a pneumatic company
Old Apr 1, 2006 | 04:34 PM
Rick's Avatar
Rick
Stu, i know u really like urs, but in my car - due to traction - i could do with something rpm/speed sensitive - can urs do that?
Old Apr 1, 2006 | 04:35 PM
Jamz's Avatar
Jamz
stop pressing the pedal so hard
Old Apr 1, 2006 | 04:36 PM
Nope.
Old Apr 1, 2006 | 04:47 PM
Rick's Avatar
Rick
the Apexi avcr does - any experience with that?
Old Apr 1, 2006 | 04:59 PM
Phil, if all you want is fixedboost at 30psi like you said the other day, use a manual boost controller, they are fantastic for doing that job.
No wastegate creep as the actuator sees nothing till the MBC opens, and no spikes, with a reaction time that no electronics can match.
Old Apr 1, 2006 | 06:34 PM
ON-UJAH's Avatar
ON-UJAH
I use a Profec-B Spec II - it works. No boost/rpm though, just two set levels. Still it only cost about 150 quid.
Old Apr 2, 2006 | 07:16 PM
JjCoDeX75's Avatar
JjCoDeX75
Hi mate,
I am using a Blitz SBCi Colour (or color if you are american!!!). It is very very good indeed. It has both Speed or RPM mode variable boost control, allowing you to map up to four different boost settings.
This does the job of both the Power Meter and Blitz ID that preceeded it, all in one box.
Very very very good, and does what you want it to extremely efficiently.
BUT, a little on the dear side. Best place to buy is from a recognised jap importer on Ebay. If you do, you can usually get for about 450 quid new!
Hope this helps
JJ
Old Apr 2, 2006 | 07:51 PM
Thats correct, although i dont actually touch it or even look at it . Have a Large Boost-gauge next to the Stack & boost levels are on a switch. Mark set it at 2.54bar max boost on day one & it aint been touched.
Old Apr 2, 2006 | 07:58 PM
GARETH T's Avatar
GARETH T
sounds like it works well rod
Old Apr 2, 2006 | 10:53 PM
polly_x's Avatar
polly_x
Ive got an Apexi AVCR fitted that does boost levels for each gear.
Cant tell you how good it is coz I am too lazy to read read the 60 page manual at the moment. It looks good though and took a bit of fitting and I am sure it will do what I need. Just need to read the book!!!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
