Are 2wd or 4wd YB oil pumps serviceable?
Is there anything you can do with either of the above pumps to service them or clean them out etc....
Dont want to remove any screws until i have an answer lol
Originally Posted by abdr500
the clearance inside the pump is what matters best bet to stick a new one in there to much trouble if there worn
This one worked fine prior to removal and i just wanted to know if there is anything i can do whilst its out to service it. If not then back in it shall go
Originally Posted by Billabong
Spadge, they have an error and the site can't connect to the database. If you can't see the error, you probably have 'friendly error messages' set to on.
Same as feck all to me lol Thread
big_Rad
Sep 15, 2017 09:36 AM
FlashRS
13
Aug 31, 2015 06:02 PM
