Cossie + mk2 escort final wiring help please..
Old Mar 31, 2006 | 11:04 PM
Mk2_2dr_2L_Escy's Avatar
Mk2_2dr_2L_Escy
Default Cossie + mk2 escort final wiring help please..
Hi,
ive got the engine cranking over, but its not kicking..
ive got spark.. and i pulled off the fuel line that goes into the fuel regulator.. and it didn't seem to have much pressure..?? it's a bosch motorsport efi pump. if it were left to pump fuel into the atmosphere freely should it still be at high pressure??.. ill have to get myself a multimeter and do some checking i think.. the battery is almost dead again.. so ill charge it up and have another go tomorrow.
does the ecu itself have to be earthed ?? or does one of those brown wires do that for me ? and can the brown wires be connected up to the body of the car or does it have to be on the intake manifold ?
What are some other common mistakes that people make when wiring up there cossie's ??
once again any help will be greatly appreciated,
Thanks,
Damion.
Old Apr 2, 2006 | 03:37 PM
foreigneRS's Avatar
foreigneRS
Testing the future
which fuel pipe did you check? the one that is jubileed to the regulator? if so, that is the return and will not have pressure. you need to check the one that goes to the fuel rail at the other end to the reg. but you should easily hear if the fuel pump runs or not.
with the ignition switched on, unpug and plug in the phase sensor (inside the dizzy) and the pump should run (or at least it does on mine with L6 ecu)
Old Apr 2, 2006 | 05:40 PM
davidreader5's Avatar
davidreader5
MK2,
You have PM.
Dave R.
Old Apr 2, 2006 | 05:41 PM
davidreader5
MK2,
You have PM.
Dave R.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
y4n
Aug 17, 2015 12:12 PM
Vincereese
Aug 16, 2015 06:38 PM
