MONDEO FRONT BRAKES,HOW EASY TO FIT
Old Jul 30, 2004 | 07:09 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
Default MONDEO FRONT BRAKES,HOW EASY TO FIT
should be piss easy i know,but aint got a manual and i need to fit some tomorrow morning very early as the pimp car has gone tits up
i take it there aint no special tools to use,just a staight forward calipler off,move piston over and put new ones in?
Old Jul 30, 2004 | 07:32 PM
stevedohc16v's Avatar
stevedohc16v
Yep thats about it m8, you need a 7mm allen key to remove the caliper guide pins then whip the caliper off pull the pads out push the piston in (G clamp is the best way) then refit the caliper and tighten the caliper guide pins back up after putting a bit of copperslip/ grease on em.
Steve
Old Jul 30, 2004 | 07:38 PM
dave green's Avatar
dave green
If your changing the discs as well make sure you have a large hammer. they can be a right bitch to get of.
Old Jul 30, 2004 | 07:40 PM
apples24's Avatar
apples24
yes mondeo discs are reet fookin coonts sen fook loads siezed solid and fook me do they need a beating to remove
original
Apr 28, 2026 05:20 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
track.focus'd
Aug 12, 2015 05:53 PM
Aug 10, 2015 12:08 PM
Red_bull
Aug 9, 2015 08:34 AM
