RST help urgent
Old Mar 30, 2006 | 02:19 PM
boost mad's Avatar
boost mad
Default RST help urgent
im not getting a spark, help
Old Mar 30, 2006 | 02:20 PM
Damienholmes's Avatar
Damienholmes
Plugs, coil, ?
Old Mar 30, 2006 | 02:24 PM
sandyRS16i's Avatar
sandyRS16i
dizzy, leads, dizzy cap, rotor arm..........
Old Mar 30, 2006 | 02:28 PM
SafeChav's Avatar
SafeChav
Any other clues????
Old Mar 30, 2006 | 02:29 PM
boost mad's Avatar
boost mad
leads, plugs cap are new and seem fine, rotor arm not new, but its clean and looks fine
boost mad's Avatar
boost mad
Originally Posted by safechav
Any other clues????
what else will help mate
Old Mar 30, 2006 | 02:30 PM
SafeChav's Avatar
SafeChav
As with most other RST's i expect the sensor has broken down in the dizzy. Give it a test.
Old Mar 30, 2006 | 02:31 PM
boost mad's Avatar
boost mad
that was a thought, how do u test it, we have tried test but be fucked if we tested it properly lol
Old Mar 30, 2006 | 04:10 PM
cuvner's Avatar
cuvner
first is there a spark from the main coil lead to dizzy cap?( take lead off dizzy, hold it with insulated pliers and hold close to side of engine!) If no then try testing the leads to the coil(12v bulb and fix 2wires to bulb and +/- wires which go to coil) get a mate to turn engine over if the bulb flashes then its your coil, if no then its either bad earthing, look at all your earthing points, try running a earth wire from -bat terminal to dizzy securing bolt and do the same but to the securing bolt of the silver ecu! If still no luck then try fuel pump realy is it burnt out? Does ur immobiliser play up? last but not least ur dizzy and the little box a magic on the side, replace dizzy and the hall effect sensor as the sensor alone is £70 but u can probably find second hand dizzy's cheap or borrow one to make sure it is that
phew almost outa breath, good luck
Old Mar 30, 2006 | 04:34 PM
SafeChav's Avatar
SafeChav
The distributor doesn't run to the coil on these cars it send the signal to the ecu which processes and/or modifies it and the coil is fired by the ECU.
Old Mar 30, 2006 | 04:46 PM
cuvner's Avatar
cuvner
yea it runs to the ecu which inturn goes to the coil, so if the dizzy doesnt work cuz the coils inside it hav broken down, corrosion or whatever then the signal to the ecu cld be wrong or there may not be a signal for the ecu, correct?
Old Mar 30, 2006 | 05:01 PM
SafeChav's Avatar
SafeChav
Yea but connecting an earth onto the coil won't show a fault because its the negative side that fires the coil.
Old Mar 30, 2006 | 05:38 PM
cuvner's Avatar
cuvner
fitting an extra earth wire to the dizzy.body can help the signal to the amplifier, it reduces the resistance which makes the signal clearer inturn geting a better more powerful spark.
The earth to the amplifier is the most important connection in the system, so the book says!
Just waht i read on cvh ignition tuning
Old Mar 30, 2006 | 05:44 PM
SafeChav's Avatar
SafeChav
Sorry my apologies i mis read that i thought u were talking about the coil. It shouldn't need it to be fair but it can't do any harm
Old Mar 30, 2006 | 06:28 PM
boost mad's Avatar
boost mad
thanx for the help guys, gon have another go tomo. we have tried to coils and dont get anything out of either of them. we have added an extra earth strap to the dizzy aswell. will do other checks tomo.
thanx again
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
`spotty
Sep 25, 2015 11:41 PM
Billy_RS
Sep 13, 2015 04:17 PM
