Problem with Brakes!
Right,
The brakes were bled up before the engine was fitted as we removed the ABS and fitted new lines! It took some effort and loads of time but all seemed fine so then we fitted the engine.
Now it is all running there is no brake pedal, it is just going to the bottom as if all of the brake pressure has been lost!
The hose to the servo seems fine but has anybody got any other things to check or ideas what it could be?
sounds like a bleeding problem...
Check out this link:
http://wheels.vc.org.ua/petrunko/escort/0686-09.pdf
pag 19
(pay particular atention to fig 23.6)
hope it works!
good luck!!!
pag 19
hope it works!
good luck!!!
