Who has drilled their block to take a CPS?
Old Mar 29, 2006 | 10:39 PM
SafeChav's Avatar
SafeChav
Default Who has drilled their block to take a CPS?
Has anyone successfully drilled their block to take a EFI cps? If so has anyone got any pictures? I'm a bit jubious about doing it and also wanted to see how others have done theirs
Old Mar 30, 2006 | 05:57 AM
fredy's Avatar
fredy
if someone has some mesures it will help i need too
Old Mar 30, 2006 | 07:13 AM
Gordon1's Avatar
Gordon1
have you got the block out
Old Mar 30, 2006 | 10:14 AM
SafeChav's Avatar
SafeChav
It will be coming out......the reason i ask is because on a factory set up the hole is very big, and that adapter plate bolts in, then the sensor goes into that, i wonder if anyone has done it any other way, but then i should imagine its tricky getting the clearance right.
Old Mar 30, 2006 | 11:22 AM
nigel b's Avatar
nigel b
ive done it on a milling machine
easy enough
ive got the dimensions at home somewhere
Old Mar 30, 2006 | 06:07 PM
scort's Avatar
scort
Indeed, it's dead easy. I have the dimensions also somewhere! As Nigel says, the best way to do it is use a vertical milling machine.
Steve
Old Mar 30, 2006 | 06:09 PM
SafeChav's Avatar
SafeChav
Hmmm, problem is the engine isn't being stripped down its only done 3.5k on a re-build. So its not going to be easy getting a whole engine on a milling machine surely?
Old Mar 30, 2006 | 06:12 PM
scort's Avatar
scort
Mag drill then would be your answer!
Steve
Old Mar 30, 2006 | 06:13 PM
SafeChav's Avatar
SafeChav
Right ok, exscuse the ignorance but what is one of them
Old Mar 30, 2006 | 06:21 PM
scort's Avatar
scort
A drill that has an electromagnetic base. You can switch it on, and it will hold itself to the end of your block, allowing you to drill at a perfect 90degrees.
Steve
Old Mar 30, 2006 | 06:34 PM
SafeChav's Avatar
SafeChav
Ah right i see fantastic
Looks expensive though
Old Mar 30, 2006 | 06:36 PM
scort's Avatar
scort
I have rented one before from a local engineering company.
Paid about £20 for a couple of days.
Steve
Old Mar 30, 2006 | 06:39 PM
nigel b's Avatar
nigel b
a decent milling machine will easily fit the engine on it
the one ive got waiting to do is a short block with sump on still
i think its a 30mm bore and a seperate m6 hole
Old Mar 30, 2006 | 06:41 PM
SafeChav's Avatar
SafeChav
Thats the problem though my engine has the head and everything still on it, and i'll be damned if its coming off i've already had the head off once in 3.5k miles
Old Mar 30, 2006 | 07:00 PM
g1234's Avatar
g1234
mag drill your best bet any local hire station will hire them out vcheap
Old Mar 30, 2006 | 07:01 PM
SafeChav's Avatar
SafeChav
Thats a good idea didnt think of that
Old Mar 31, 2006 | 07:30 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Sod all that!!!
Just fit a bottom pulley with the trigger setup built into it.
£45 Job done
Bolt it on and away you go
Old Mar 31, 2006 | 10:23 AM
SafeChav's Avatar
SafeChav
Originally Posted by Jano_OddKidd
Sod all that!!!
£45 Job done
I've got all that stuff but to be honest its probably just as much hastle having to drop the engine for a cam belt change
I presume you use the sierra 1800 pulley yeah?
Old Mar 31, 2006 | 11:51 AM
JesseT's Avatar
JesseT
I drilled mine with a hand drill and the engine still in the car. Dead easy.
the result
Old Mar 31, 2006 | 12:18 PM
SafeChav's Avatar
SafeChav
Fook me that looks like you did a good job of it. How the hell did you drill a hole of that size with a hand drill
Old Mar 31, 2006 | 07:16 PM
Versus_Creations
Ask me a question!
Sod all that!!!
£45 Job done
What a load of waffle mate.. Who told you that you have to drop the engine..
It make it so easy to change a belt that you dont even need to take the bottom pulley off Nothing to do with droping the engine...
Old Mar 31, 2006 | 07:19 PM
SafeChav's Avatar
SafeChav
Well you haven't answered the question i asked you yet. Using a sierra bottom pulley (which is what i asked you and you didnt reply to) you HAVE to drop the engine.
Maybe im just lost without the pretty pictures.
Old Mar 31, 2006 | 07:20 PM
Versus_Creations
Ask me a question!
dude with that setup you do NOT have to drop the engine to change belts.
Yes it is the same looking setup as the sierra
Old Mar 31, 2006 | 07:21 PM
SafeChav's Avatar
SafeChav
How are you meant to get the belt past the pulley???
Old Mar 31, 2006 | 07:28 PM
Versus_Creations
Ask me a question!
how thick do you think a cam belt is?
I do regular cam belt changes for many RS's, none of them have the engine dropped!
Regards
Old Mar 31, 2006 | 07:45 PM
SafeChav's Avatar
SafeChav
Well i'm sure where theres a will theres a way like anything but i don't fancy pinching the belt forcing it through a small gap. I didn't think the pulley would allow a good clearance?
Old Mar 31, 2006 | 08:04 PM
nigel b's Avatar
nigel b
safechav
maybe not alot of clearance but there is enough
Old Mar 31, 2006 | 08:18 PM
SafeChav's Avatar
SafeChav
nigel b Thanks for that
Old Apr 1, 2006 | 07:14 AM
JesseT's Avatar
JesseT
First a 10mm hole and then the rest with a 30mm tapered drill. Some thing like this:
Old Apr 1, 2006 | 10:29 AM
SafeChav's Avatar
SafeChav
Ahhhhhh, now im beginning to understand Guna give that a go i reckon looks easy enough. Was that the actual drill you used?
Old Apr 1, 2006 | 11:00 AM
JesseT's Avatar
JesseT
No, that's not the one. That's just the first image google gave for a step drill.
Old Apr 1, 2006 | 11:02 AM
SafeChav's Avatar
SafeChav
Ah ok I was looking at the block again yesterday and its only about 4mm thick isn't it? Is the material very hard to drill through?
Old Apr 1, 2006 | 11:29 AM
JesseT's Avatar
JesseT
It's very soft actually.
Old Apr 1, 2006 | 11:31 AM
SafeChav's Avatar
SafeChav
Fantastic I was going to ask where you got your drill bit from but i see your from finland. Unless you bought it online?
Old Apr 1, 2006 | 05:02 PM
AJC's Avatar
AJC
i use one virtually every day, if you did not live so far away, i would
of done it for you
Old Apr 1, 2006 | 05:04 PM
SafeChav's Avatar
SafeChav
Thanks very much for the offer, worst comes to worst im sure i could bring it you
I'm guna give the hand drill a go though i think JesseT did an excellent job, so i'll have a bash
Old Jun 14, 2006 | 09:46 AM
Schmidi's Avatar
Schmidi
Could you pls insert an image of this solution?
Where do you mount the sensor in this case?
Old Jun 14, 2006 | 06:45 PM
Versus_Creations
Ask me a question!
click sig for pics mate.
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
