does anyone know how to test if injector plugs wiring works
hi can anyone tell me how to check the wiring to the injectors to see if they are activating the injectors
cheers peeps
cheers peeps
i dont think they pluse 12v though, youd be better off with a multimeter, set it to 20volts and touch the pins of the multimeter on the connections then crank the engine.
be careful you dont bend the pins inside the clip though, took em a while to figure out where the missfire was coming from
Injectors are 12v, and xr-stu that sounds near impossible to measure with a multimeter, digital meters don't respond rapidly to sudden changes. The bulb idea seems like a good idea, either that or plug in a spare injector and crank it and you'll see/feel the injector working.
Belive me, The bulb works, Ive tried this method on a few cars including a cossie
ah right, just on my zetec it was only showing 1.5v or there abouts cranking the engine over!
the multimeter wasnt giving accurate readings but was showing a constant change in voltage. but then again i dont know many light bulbs that give an accurate reading of voltage either!
Zoggon
Aug 10, 2015 10:39 AM
