Oil in air box
Don't ask - I don't know
As long as it isn't sloshing about it's fine. As the engine 'breathes' you get oil vapour which over time will deposit a layer. Perfectly normal.
this is designed to be "green" by making the engine inhale all the oil vapours back in, vent it away from the inlet imo.
oil vapour increases the chance of det.
if you want a green car sell it and go buy a micra
As per Matt, so a seperate oil breather system is a good idea (or catch the oil vapour in a coke bottle if skint/tight (delete as applicable) better than the engine digesting it. Plus, under hard cornering/engine breathing badly, I think the system can literally squirt oil into the air box (hence watch out for 'puddles'.
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
