ARRGHHH! which plug champ c57c or c59c!?!?
Mar 29, 2006 | 02:24 PM
rang too different well know tuners
1 said for for champion C57c plugs for my RST (16psi)
the other said C59c
which one is correct?
Mar 29, 2006 | 02:37 PM
NGK BCR8ES
Mar 29, 2006 | 02:46 PM
nope bin told there a load of poo poo davie, especially if running 16psi
Mar 29, 2006 | 03:05 PM
Quote:
Originally Posted by T28 RST
NGK BCR8ES
What about Ford Motorcraft Super spark plugs? Rated or not?
Mar 29, 2006 | 03:19 PM
aint nothing wrong with NGK BCR8ES
Mar 29, 2006 | 03:20 PM
Naff all wrong with ngk's i had them in my old s2 running 18 psi.
Mar 29, 2006 | 08:08 PM
Everyone seems to have different views on this topic....I was told by a well respected tuner to use big turbo escort cossie plugs, pp8's i think they are.....ain't had no probs with em, good for big boost as well! Got em from Ford, pricey tho!
Mar 29, 2006 | 08:18 PM
Mar 29, 2006 | 08:41 PM
Quote:
Originally Posted by Rallyesport
16 PSI is nothing.
Thats all im running
Mar 29, 2006 | 09:22 PM
59c for anything over 14 psi
the other for up to 14 psi , its what ive used on 4 turbos , no problems whatso ever , i dont think theres a best spark plug either
Mar 29, 2006 | 09:49 PM
071s £2.20 each from ford
Mar 29, 2006 | 10:27 PM
Mar 30, 2006 | 07:43 AM
dunno davie just going by what MSD told me yesterday on the phone
so c59c will do then?
alex what you find the life of the ford o71s are like?
cos they pretty cheap!
Nothing, because 16 PSI is not extreme boost. The plugs you would have gotten at Ford would have done the job. Buy NGK BCR8ES cheaper than 57/59c and good enough or just as good.
Mar 30, 2006 | 07:48 AM
think i mite just go for the ford jobbies then, unless them NGKs are a better option
Mar 30, 2006 | 08:09 AM
Quote:
Agreed
Myself and Mr C run these plugs with no problems at 2 bar of boost and 300+ bhp. Need we say anymore?
Mar 30, 2006 | 08:31 AM
well thats that sorted then ford ones it is! cheers lads
Mar 30, 2006 | 09:46 AM
NGK BCR8ES plugs are fine mate and are only £7.99 fo 4 at halfords
Mar 30, 2006 | 11:41 AM
im usin the ford plugs at 21psi with a gap of o.65, dont have any probs, change them every 3-4 k.
gunna get a group a coil and open the gaps up a bit hopefully
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
