cossie now sparks but fuel leaking through breather pipe ??
hi cheers to all that helped on sparking problem
got it sparking now but still wont run i have noticed that the breather pipe that runs to the top of fuel regulater to the inlet manifold by the air temp (brown switch) has a bit of fuel in it when i pulled the pipe of it the black one breather a little bit of fuel trikled out any ideas peeps
got it sparking now but still wont run i have noticed that the breather pipe that runs to the top of fuel regulater to the inlet manifold by the air temp (brown switch) has a bit of fuel in it when i pulled the pipe of it the black one breather a little bit of fuel trikled out any ideas peeps PassionFord Post Whore!!
fuel pressure reg buggered i reckon - feul should not be able to get from the inside of the reg to the top side of the diaphragm where the vac/pressure is applied to vary the pressure...
JoeyBoyden
Aug 18, 2015 10:52 PM
Zoggon
Aug 10, 2015 10:39 AM
