i had fun last nite
Old Mar 28, 2006 | 08:55 PM
Fiestamatt's Avatar
Fiestamatt
Default i had fun last nite
after 2 weeks of owning the car shes already on a flatbed lol.
Matt
Old Mar 28, 2006 | 09:18 PM
Sean_RS's Avatar
Sean_RS
sorry to hear that mate... what happened...
welcome to owning a frst
Old Mar 28, 2006 | 09:45 PM
rauri's Avatar
rauri
up in smoke........
they aint that bad
oh hold on when did mine last run.................
Old Mar 28, 2006 | 10:28 PM
Sean_RS's Avatar
Sean_RS
check my display pic
Old Mar 29, 2006 | 10:34 AM
Lou Lou.'s Avatar
Lou Lou.
Oh no what happened ??
Old Mar 29, 2006 | 12:17 PM
rauri's Avatar
rauri
up in smoke........
he bought a frst
Old Mar 29, 2006 | 12:51 PM
Lou Lou.'s Avatar
Lou Lou.
Pmsl thanks for that maybe you guys should of looked out for a decent one
(ok im gonna cry if mine breaks down now )
Old Mar 29, 2006 | 02:00 PM
rauri's Avatar
rauri
up in smoke........
there wasnt actually anything wrong with mine,it ran fine for a year and a half...........then i decided to pull the enigne out and take it to bits
Old Mar 29, 2006 | 06:59 PM
fiestaturbo1984's Avatar
fiestaturbo1984
can i join the club, well mines not on a flatbed but it should be, my exhaust has snapped at the downpipe im still having to use it too. trying not to take it above 2k so i dont blow oil seals on turbo
Old Mar 29, 2006 | 10:02 PM
Sean_RS's Avatar
Sean_RS
oh that hurt...............
Old Mar 29, 2006 | 10:31 PM
xr-stu's Avatar
xr-stu
just read your other thread mate, i mentioned it in there aswell but did you check the inertia switch?!
Old Mar 30, 2006 | 07:16 AM
Lou Lou.'s Avatar
Lou Lou.
Old Mar 30, 2006 | 09:42 AM
sy16v's Avatar
sy16v
Downer mate hope you get it sorted soon
Old Mar 31, 2006 | 08:33 PM
Fiestamatt's Avatar
Fiestamatt
update!!
seems to be working fine now after replacing the yellow fuel pump relay, hard to belive that something so little could cause so much problems lol.
Thanks for ur help peeps
Matt
Old Apr 1, 2006 | 12:13 PM
JasperJ's Avatar
JasperJ
If it still isnt right after this, replace the red Relay as well, as the power goes thru the yellow relay first and then into the red one, then out to fuse 19 which supplies the fuel pump. I had the same intermittent problem & replaced both relays & the fuse, now it hasn't missed a beat for over 12 month.
Old Apr 1, 2006 | 09:15 PM
BRAMMER's Avatar
BRAMMER
I'm contantly touching wood as i did'nt make FITP last year as my turbo decided it wanted to spin backwards at 120mph (on a private runway ) so took the top end to bits and it took ages to get it all sorted and up and running.
Hope you get the problem sorted as its the kind of problem you could do without, dodgy fueling. You don't want detination from running lean
Prickly_buzz
Dec 7, 2017 09:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
gingeRS
17
Oct 2, 2015 09:42 AM
jay030787
Sep 18, 2015 04:38 PM
