Stage two set up for saph
Old Mar 28, 2006 | 07:38 PM
cossiescott's Avatar
cossiescott
Default Stage two set up for saph
Does anyone know the settings for a 4x4 saph running greens,chip,-31 and a 3 bar? i.e fuel pressure, boost, co% etc etc
Old Mar 28, 2006 | 08:04 PM
JamesH's Avatar
JamesH
If possible contact the person who made the chip, they should have all this information to hand
Old Mar 29, 2006 | 09:13 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
fuel pressure is 3.2 bar at idle.
Boost should be 22psi ish minimum,
C,O level, some people ignore the co level and set the car so the hc level is at its lowest. as long as the co isnt way low.
but as said really you need to check with the chippy!
JK12
33
Apr 26, 2021 12:09 PM
Nov 3, 2015 04:08 PM
turbowag
Sep 3, 2015 08:07 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
Cragrat
Sep 2, 2015 08:25 PM
