1ST COSSIE LOADS OF PROBS IDLING @2200RPM??????
Old Mar 26, 2006 | 11:44 PM
BIGCARP321's Avatar
BIGCARP321
Default 1ST COSSIE LOADS OF PROBS IDLING @2200RPM??????
HI ALL
JUST AQUIRED MY FIRST COSSIE IT'S AN EARLY SAPPHIRE 4X4 ON A 1990 H PLATE, PURCHASED IT OFF A GOOD MATE WHO HAS HAD IT SAT IN HIS GARAGE DOING NOTHING (I MEAN NOTHING OT EVEN STARTED!!!) FOR OVER A YEAR, HAD IT ABOUT 4 WEEKS AND AM WELL IMPRESSED, APPARENTLY RUNNING ABOUT 360 BHP???
PROBLEMS I HAVE BEEN HAVING ARE STARVING OF FUEL OR OVER FUELLING WHILST DRIVING AND ENGINE AT NORMAL TEMP JUST DIES LEAVE IT A WHILE AND IT WILL START AGAIN ONLY FOR THE PROBLEM TO RETURN LATER MAYBE A MILE OR 20 MILES DOWN THE ROAD, SORTED THIS OUT BY DISCONNECTING THE ICSV, IT HAS BEEN RUNNING FINE SINCE (@2 WEEKS) THEN ALL OF A SUDDEN YESTERDAY STOPPED AT SOME LIGHTS AND IT WAS LIKE THE THROTTLE CABLE WAS STUCK, AND IT HAS BEEN IDLING ABOUT 2200 RPM, REMOVED ALL THE PIPES TODAY AND CHECKED EM, REPLACED ALL THE JUBILEE CLIPS WITH NEW ONES, ALSO REMOVED DUMP VALVE AND CHECKED DIAPHRAGM ALL SEEM OK BUT DUMP VALVE DOES NOT SEEM TO BE WORKING NOW, MIGHT JUST BE ME THOUGH.
AS I SAID B4 THIS IS MY FIRST COSSIE SO KNOW VERY LITTLE ABOUT THEM APART FROM THEY ARE A WORLD OF TROUBLE AND I CAN SEE ME GETTING A WHOLE LOAD OF EARACHE FROM THE MISSES FOR THE AMOUNT OF MONEY THAT IS PROBABLY GOING TO BE HAVE TO BE SPENT ON IT.
THE CAR HAS DONE ABOUT 104K BUT HAS HAD AN ENGINE RE-BUILD IN 2001, WITH A LOAD OF NEW STUFF CHUCKED AT IT.
HAVE YOU SEEN THE PRICE OF A NEW ISCV VALVES £323 FROM FORD!!!!
DOES ANYONE KNOW WHERE I CAN GET ONE CHEAPER???
ALSO I GOT QUITE CHEAP INSURANCE FROM CHRIS KNOTT GROUP £776 FULLY COMP DECLARING ALL MODS AND I HAVE A BAN FOR SPEEDING, 27YEARS OLD, IS THIS CHEAP????
SORRY FOR ALL THE QUESTIONS AND THANKS FOR ANY REPLYS IN ADVANCE.
CHEERS
SIMON
Old Mar 26, 2006 | 11:55 PM
jon@work's Avatar
jon@work
Check for an air leak after the throttle body - blown inlet or plenum gasket sounds favoutite. Also check that you haven't lost the idle screw from the bottom of the throttle body.
I used to insure through Chris Knott - £776 sounds an OK price.
Old Mar 28, 2006 | 09:02 AM
BIGCARP321's Avatar
BIGCARP321
YEAH THAT IS NEXT THING I'M GONNA DO. MAYBE THIS WEEKEND?
IF IT HAS A GRP A HEAD GASKET CAN THEY BE RE-USED??? OR IS IT BEST TO PUT A NEW ONE ON?
CHEERS
Old Mar 28, 2006 | 10:56 AM
jon@work's Avatar
jon@work
new one
Old Mar 28, 2006 | 11:29 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Re: 1ST COSSIE LOADS OF PROBS IDLING @2200RPM??????
CHEERS
They're only a heap of trouble if you fix them on the cheap I can't think of any gaskets that are re-useable on the YB.
Seriously, they are VERY reliable if looked after, they only turn to trouble when messed with
Good luck with, I am sure that once sorted it will be great.
PS: avoid caps when posting, it puts people's backs up and you are less likely to get an answer
Old Mar 28, 2006 | 03:29 PM
cossiegreg1's Avatar
cossiegreg1
the iscv can be cleaned im sure if you do a search on here you can find the proper way to do it! but i just take it out squirt it with carb cleaner until the manky shit runs clear i think the cutting out problem could be your water temp sensor (blue one-back of the head.)only about £25 from woodford garage.a guy off here sells them on ebay,i seen a pack of three different sensors for £28 i think his user name is matt lewis
Old Mar 28, 2006 | 09:42 PM
rapidcossie's Avatar
rapidcossie
if it cuts out once up to temp then wont start for ages it might be the blue coolant temp sensor on the head. inlet side.
i always say that for these types of probs but mine did the exact same plus its the cheapest sensor so doesnt hurt to change it first.
Old Mar 28, 2006 | 10:29 PM
BIGCARP321's Avatar
BIGCARP321
mmm it was only cutting out untill i disconnected the iscv???? ran fine for 2 weeks after that then went tits on sat with the idle prob, gonna strip the inlets this weekend and replace gaskets etc will see if i can get new coolant plugs this weekend as well, have booked in for rolling road at garage in aldershotas its the closest i have found that do 4x4s from portsmouth unless anyone knows any others????? also is there such a thing as a grp A cam belt???has not been changed since 01 but has only done 4k since then but really needs changing asap especially b4 rolling road. are there any others on the forum who live in fareham / portsmouth area in hants that anyone knows of?????
cheers all
Chas
Oct 5, 2015 07:13 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
