best value for fuel pressure and egt
Old Mar 26, 2006 | 08:12 PM
sygjim's Avatar
sygjim
Default best value for fuel pressure and egt
Hi,
on my cossie 4*4, i had fit a fule pressure gauge and a egt gauge. the exhaust sender is fit in place of the lambda sensor on the turbo because i didn't want to drill the turbo .
yesterday, i had fit light blue injectors and new chip.
i would like to know if i need to increase the fuel pressure and what is the best value for exhaust temp that i should have ?
the temp is very low so i think that i am too rich
Old Mar 26, 2006 | 08:44 PM
abdr500's Avatar
abdr500
it all depends on alot of things but as a rule you should have 3.5 bar at idel with vacume pipe off
Old Mar 26, 2006 | 08:57 PM
sygjim's Avatar
sygjim
thanks, i have this value
but, as i had put bigger injectors, i was thinking that i need to increase the pressure
Old Mar 26, 2006 | 09:02 PM
abdr500's Avatar
abdr500
is the pump a uprated item as the flow is waht you realy want to look out for
Old Mar 27, 2006 | 04:44 AM
sygjim's Avatar
sygjim
the pump is a bosch 044
thanks
Old Mar 27, 2006 | 08:15 AM
abdr500's Avatar
abdr500
set it to 3.5 bar idel with vacume pipe off and then take to a tunner or mapper .off the shelf chips for grays or light blues are no good
Old Mar 27, 2006 | 08:29 AM
sygjim's Avatar
sygjim
i know for live mapping, but i leave in France
not many tuner who are doing the live mapping
Old Mar 27, 2006 | 11:55 AM
Billabong's Avatar
Billabong
Fuel pressure doesn't necessarily need to be increased - that's why we go up in size, with injectors that flow more fuel.
BUT, you need to know what the chip was set for - from the mapper who created the chip.
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
SMILER258
Sep 28, 2015 09:04 AM
