Brake hose exploded!! Time to sell up me thinks...
This is what shouldn;t happen at 50mph when the MOT guy is out testing the brakes on your car!!
Yup, failed on handbrake, service brake (brake hose), bit of welding needing done on the sill, tiny bit on floor pan by seat mount, 2 front tyres (knew if would
Fed up and going to sell it once MOT and brakes fitted
Just not worth keeping a car that does this all the fooking time
Unfortunately with RST's this is the story. If it wasn't for the attachment I have to the car, it would have prob gone 7 years ago. Every year there was a disaster. Broke it once, kept shell, wheels, etc. Rebuilt it at a cost and boom, head looked like someone had used Oxy acetylene on it. For absolute constant unreliability you can't beat a Ford. Had a MR2 Turbo I sold to help fund the comeback and it never missed a beat once. Say's something I think
We 'think' it may have been chaffing on the strut, but not too sure
Not the easiest thing to get to with MOMO Arrows on ya car (not much space)
I just fed up now, enjoy this years shows and then sell up
Did the MOT tester not spot it BEFORE test driving it?
No mate
We passed him taking the car back to my house (driving) as was going to Post Office, popped into garage on way back to see what outcome was, fluid all over the entrance to the garage
He got back, was VERY concerned and said it's at yours, needs fixing and dangerous to drive
Nothing to say he'd/they'd have a go at repairing the car, who the hell am I? A full blown mechanic???
Really had enough
Really had enough
The only way that would have exploded would be if there was a serious kink in the hose, or if it had rubbed clean through the braided material.
You any idea what these hose materials are pressure tested to? I know, and let's just say it's more than your braking system can supply!
Originally Posted by EIL132
Flexi should joint is welded to inner wing, so shouldn't have been chaffing on anything
All I can assume is the rubber grommet came out from strut and was chaffing, something you don't check for is it
i take it the mot tester was driving the car at the time it happend mate ??????
if so why thay have a break tester for that.
if he had an accident what would of happend then????????
The break testers used to be a motion type device. You drove the car, braked and a pendulum swung to tell you the brake imbalance. Depends on their equipment although I'm not sure if the old ones are still legal!
no mate ive had mine 3 years and never once did any one take it out.
gearbox does not come under mot anyway.
did it happen when he was taken it back to your house or when he toke it up the road for a test drive????????
Barry, don't they have to drive it due to LSD in the gearbox??
sorry but no they dont have to check that
I wouldnt let an MOT tester drive my RST.
As far as i know all mot work should be undertaken on the mot premises ?
andy rst is right, no car is to be driven on the road when it goes for an mot.
i would say thay just wanted to drive it to see what it does as some do.
was the hose spotted before thay had taken it for a drive ???? or a thrash ????????
not that an RST is 4WD tho
Barry, answered the hose question twice above I think already, no it was not sptted or you got to be a complete prat to drive it ain't ya!!!
Local garage (trust 110%) do NOT thrash my car at any time and have worked on it many a time and very happy with said work
Andy, good point matey
Did have advisories on it, also wasn't home to be told car is un-roadworthy
Got told this when saw them at MOT station
Absolutely no reason why an MOT tester should take the car on the road. If i were you I would find out why it was being driven. If he has any reservations about a cars safety then it should be noted on the sheet, if its exceptionally dangerous then they will say its unfit to drive, they should not test drive it to see. Thats a load of bollox bout the diff.
"The statutory test does not specifically include a road test of the vehicle, except for vehicles which cannot have the performance of the brakes tested on a roller or plate brake tester.
A road test, however, is permitted if the tester considers one is necessary to check the results of an inspection. The tester must be qualified to carry out the road test, and must ensure it is safe to conduct that test."
A car with an LSD should NEVER be used on a MOT braking machine
Very easy to screw the diff up completely
, ALWAYS insist on the machine they put inside your car, be it electronic or the mechanical swinging one.
As Pon says, them hoses are tested at stupid pressures but it could be something simple like it was kinked badly when fitted and has gradually been degrading until Bang
Like you James I got totally sick of spending money on what shouldnt have needed spending on, so I decided to get rid and buy something that doesnt need fixing every weekend. The Audi has been great upto now
, but miss the turbo rush
Will get something worth spending money on when the time is right
.Very easy to screw the diff up completely
, ALWAYS insist on the machine they put inside your car, be it electronic or the mechanical swinging one.As Pon says, them hoses are tested at stupid pressures but it could be something simple like it was kinked badly when fitted and has gradually been degrading until Bang
.Like you James I got totally sick of spending money on what shouldnt have needed spending on, so I decided to get rid and buy something that doesnt need fixing every weekend. The Audi has been great upto now
, but miss the turbo rush Will get something worth spending money on when the time is right
, ALWAYS insist on the machine they put inside your car, be it electronic or the mechanical swinging one.the machine only turns the wheels over at 5-6 mph, how can that be worse than wheel spinning in a corner and spinning the LSD up at high speed?
One of the front brake claiper bleed nipples snapped mate, hence continuousl letting fluid out of the caliper
It was fooked big time!
Shame I couldn't attend, but TRAX is a definate and don't know anything else that's in between, can't be on stand at National Day 'cos I got a 3i shell LOL
