Closed loop lambda control.
Old Mar 25, 2006 | 05:49 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Closed loop lambda control.
Whats all required ? My 93 reg 4x4 saph has a lambda sensor in it can this be used ? Oh aye and how much ?
Old Mar 25, 2006 | 05:51 PM
GARETH T's Avatar
GARETH T
yes your sensor can be used
do you have a ford baby board in your l8?
Old Mar 25, 2006 | 05:56 PM
KSA-Cossie's Avatar
KSA-Cossie
Not a clue gareth im new to cossie world.
Old Mar 25, 2006 | 05:59 PM
GARETH T's Avatar
GARETH T
take your ecu out of your car, and post a picture of the inside
Old Mar 25, 2006 | 06:01 PM
KSA-Cossie's Avatar
KSA-Cossie
Don't know how to take the glovebox out. If the lambda can be used is it just a case of different chip and away you go ?
Old Mar 25, 2006 | 06:03 PM
gingeRS's Avatar
gingeRS
to take the glove box out just open it and give it a good yank towards you
Old Mar 25, 2006 | 06:11 PM
KSA-Cossie's Avatar
KSA-Cossie
Ok will give it a go tomorrow,what if i don't have this baby board ?
Old Mar 25, 2006 | 06:14 PM
GARETH T's Avatar
GARETH T
you need to get hold of one to be able to have closed loop
Old Mar 25, 2006 | 06:18 PM
CosKev3's Avatar
CosKev3
I'll be interested to see what standard one looks like too
If my car is running standard chip does that deffo mean I've got standard board????????
Have got car booked in at MSD for live map on greys with closed loop,so could do with finding out
Thanks
Old Mar 25, 2006 | 06:21 PM
KSA-Cossie's Avatar
KSA-Cossie
Ok gareth thanks for the info m8.
Old Mar 25, 2006 | 06:27 PM
KSA-Cossie's Avatar
KSA-Cossie
Found this which has helped even more.
http://www.motorsport-developments.c...closedloop.htm
GARETH T's Avatar
GARETH T
yes mate
Old Mar 25, 2006 | 06:32 PM
CosKev3's Avatar
CosKev3
yes mate
Cheers Gareth
Might still take a pic for you to have a look at,because I'm only going by the bloke I had ECU off saying its standard chip
It has started my car up on 4x4 standard injectors and 2 bar map sensor,does that guarantee a standard chip is fitted????????
Old Mar 25, 2006 | 06:49 PM
foreigneRS's Avatar
foreigneRS
Testing the future
CosKev3 is that a different car to the details in your sig then?
Old Mar 25, 2006 | 06:52 PM
GARETH T's Avatar
GARETH T
no mate,, it could be on a stage one,, but i bet its standard if someone sold it as standard
Old Mar 25, 2006 | 06:54 PM
CosKev3's Avatar
CosKev3
Same car m8,just running it on standard injectors etc with no boost just to get it upto MSD
Goin L8 live mapped,so needed to get it up and running to get it there
Old Mar 25, 2006 | 06:56 PM
CosKev3's Avatar
CosKev3
Ah shit,never thought about stage 1!
When you stage 1 an L8 you change the board and the chip then?????
Best take a pic tomorrow
Thanks
Old Mar 25, 2006 | 08:00 PM
GARETH T's Avatar
GARETH T
Thanks
some do,, some dont
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Marv888
Sep 26, 2015 03:44 PM
tib2220
Sep 14, 2015 12:33 PM
Si B
Sep 12, 2015 06:49 AM
