saph wont start .....
Old Mar 24, 2006 | 06:43 PM
rsrob's Avatar
rsrob
Default saph wont start .....
wondering if someone could help, ive just put a 4x4 200 block engine into a 2wd saph, i have changed it back to 2wd and its got a 2wd loom.
is the 4x4 management different ? as there is 2 plugs behind the dizzy 1 for the crank sensor and another that goes to the left hand side of the block to another sensor, what is this for ? as there is no plug for this on the 2wd management
is there anything else that may be different ? i have changed the tps to the 2wd 1 aswell
the car wont even think about starting its turning over ok but doesnt sound like its ever going to start... there is fuel but the spark is weak, i have changed the coil for a group a one and still its the same, any ideas ?
ive also noticed when turning it over the inlet pipe to the throttle body is being sucked in too, its a samco hose and doesnt feel like its weak, so is this right or not ?
sorry for the long list but im out of ideas and i need this thing to start
Old Mar 24, 2006 | 08:49 PM
whitecossie's Avatar
whitecossie
1 is for the crank sensor mate and the other goes to the dizzy i think ,,
Old Mar 24, 2006 | 09:10 PM
rsrob's Avatar
rsrob
no i have them 2 mate, on the 200 block there is 2 plugs behind the dizzy
1 for the crank posion sensor, just not sure what the other is for ?
the engine still doesnt start, i now have a good spark (timing was out a touch) and fuel ...... so why wont it start ?
gonna swap the ecu's tomoz to see if it helps, if not am i best trying to tow start it ?
Old Mar 24, 2006 | 10:32 PM
pee vee's Avatar
pee vee
One is for crank sensor
the other one is for the Knock sensor (round the other side of the block)
Have you still got 4x4 ECU??
if so, you are aware that 2wd Throttle position sensor reads the exact OPPOSITE of 4x4 one (at 100% when 4x4 one is at 0%)
dont think the knock sensor being un plugged would have too much effect.
Old Mar 24, 2006 | 10:34 PM
rsrob's Avatar
rsrob
yeh it has the 4x4 ecu but i have both tps, which 1 should it use on the 2wd loom ?
Old Mar 24, 2006 | 10:43 PM
pee vee's Avatar
pee vee
use everything 2wd
OR everything 4x4 mate.
ie loom, ecu and throttle position sensor,, every other sensor is the
same from 2wd to 4wd im pretty sure
Old Mar 24, 2006 | 10:46 PM
CosKev3's Avatar
CosKev3
You need the 4x4 TPS(PF09) with the 4x4(L8) ecu
Also if its a 2wd loom you need to swap the 2 outer wires on the TPS plug over to run the 4x4 ECU
Its funny that its sucking in the inlet hose though,are you sure you haven't got a blockage in the intercooler/turbo/airfilter???????
Old Mar 24, 2006 | 10:54 PM
rsrob's Avatar
rsrob
intercooler is a brand new rs500 style and the turbo is all piped up right as i remember
Old Mar 25, 2006 | 08:08 AM
TurboShed's Avatar
TurboShed
Cossiemodo
A Samco hose getting squished up just from turning the car over with the starter motor? Sounds pretty fishy.
DixieTheKid
Jul 23, 2023 10:16 AM
j.hammond1
30
Oct 31, 2021 05:28 PM
jdsjojo
Aug 30, 2015 07:48 PM
jdsjojo
PassionFord Swap Shop.
Aug 26, 2015 09:51 PM
