front n rear windscreen
Old Mar 22, 2006 | 07:05 PM
RST Ski's Avatar
RST Ski
Default front n rear windscreen
gota remove front n rear windscreens, are the a bugger to take out? on s2
Old Mar 22, 2006 | 10:35 PM
addiction's Avatar
addiction
just sit in the seat put your feet on the screen in the top corner and push!!
if there is a stonechip or crack anywhere on the screen it will probably break when taking it out though
Old Mar 22, 2006 | 11:32 PM
T28 RST's Avatar
T28 RST
Ok then
easy enough with a
Old Mar 23, 2006 | 06:37 PM
MikeyXR2i's Avatar
MikeyXR2i
What u need to do, is.. get in the car, lift the rubber and u will see the metal lip, get a blunt object, and tuck the rubber back behind the lip all the way round, accept the bottom, and the screen will simply lift out.
Old Mar 23, 2006 | 07:27 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
As above
Old Mar 24, 2006 | 11:08 AM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
That's how we all do it. As Mikey says the other way of tucking the rubber underneath is the other way and better if you don't want to risk cracking the screen. If you're replacing it, use your feet. Just sit in the middle of the car, one foot in the top left, one in the top right and gently push.
Old Mar 24, 2006 | 11:23 AM
John Laverick's Avatar
John Laverick
Don't forget to disconnect the wiring if its a heated front screen. There is a connection in the centre at the top as well under the clock/light.
Oct 9, 2015 07:38 PM
FlashRS
Sep 14, 2015 12:36 PM
TrevCos
Aug 17, 2015 09:08 PM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
