Pics of S2's on 16's
Old Mar 22, 2006 | 04:14 PM
D33SFV's Avatar
D33SFV
Default Pics of S2's on 16's
as above but preferably on speedline/compomotives or the likes.
I have cosworth disks on the rear and the car is going 60mm lower this weekend so 17's seem out the question.
What you got......
Old Mar 22, 2006 | 04:47 PM
Robin's Avatar
Robin
not got any pics but would stay well away from a 60mm drop, 30mm is more than enough
Old Mar 22, 2006 | 05:33 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You'd need your head examined to go for a 60mm drop. You WILL regret it. Most aftermarket shocks will bottom out close to that, so zero suspension travel will be a reality and a car that leaps around all over the road.
30mm max IMO.
Old Mar 22, 2006 | 06:10 PM
dan69's Avatar
dan69
those are lovely rims. got a set of them on the way for my series2 in 16'' as well but on a black 80spec.
Old Mar 22, 2006 | 07:25 PM
D33SFV's Avatar
D33SFV
30mm max IMO.
How low is this white one??
Looks good, I just thought I'd go 60mm to keep the wheels looking a good size as 16's are the biggest I'm going now.
Old Mar 22, 2006 | 07:47 PM
shane's Avatar
shane
as robin said,id stay well away from the 60mm drop.ive dropped mine 30mm and its boarder lining on being too low,as 17 catch!
Old Mar 22, 2006 | 07:54 PM
D33SFV's Avatar
D33SFV
I bought 17's last week without thinking about having rear discs on my car so the 17's are a no-no as they sit out slightly further. I think i'll try the 60mm springs(if at least for a photo) but listening to you guys I'll probabaly get 30mm springs.
Old Mar 22, 2006 | 10:59 PM
Christian and Beccy
#1 in Spelling Club
I can supply the springs that are fitted to mine (the white one above) for under Ł100.
They are superb.
Old Mar 23, 2006 | 01:28 PM
Combi_Chris's Avatar
Combi_Chris
c&b how much do your springs lower the car 30 mm ? or is that you just saying thats the max youd go ?
Old Mar 23, 2006 | 01:30 PM
Christian and Beccy
#1 in Spelling Club
Yes, they lower the car around 30mm, which is the most I would recommend.
Im sure they do a 60mm version, but as said before, don't do it!!
Old Mar 23, 2006 | 01:43 PM
Combi_Chris
not sure what mine is, but its too low....30 might be ok, but id like to be able to see 30mm on 17`s
Old Mar 23, 2006 | 06:14 PM
Rick's Avatar
Rick
the bigger the wheel - the higher it looks.
Old Mar 23, 2006 | 10:25 PM
Christian and Beccy
#1 in Spelling Club
....The bigger the wheel, the smaller the arch gap.
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
griffo69
Oct 4, 2015 11:58 AM
locum8
Oct 1, 2015 01:50 PM
