diff oil 2wd ???
which stuff should i use. the diff is out of the car and just been sand blasted as was covered in shite... not sure when was last changed if ever.. also how much oil will it take i guess there is a level somewhere... any help please???
Ford say SAE90 gear oil,there was a topic on here the other day about the same question,pretty sure Bernie(Gearboxman)said 75/90 fully synthetic gear oil is a better oil for the cosworth LSD when its hot
The level bung is a 10mm allen/hex key about halfway up on the diff rear casing
Pretty sure its 1.3 litres capacity m8
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
