What tyre pressures for TOTB (205/40/17) ERST
normal for top speed runs and handling, less for 1/4mile.
if your running stock road tyres your not gona come anywhere in handling or 1/4mile mind as others will have good tyres so grip, so maybe not worth arsing round with pressures really.
for 1/4 mile, just set everthing up the same as when u did 13.8 at brunters
i usually set mine at 25psi but every car is different and your running 17s so maybe a bit less. but try different pressures on the day, good luck simon
CheeRS guys I shall keep them normal for top speed and handling and maybe lower them a bit for 1/4 mile
I've ran a 13.8 at brunters with 17's and crap Avon tyres I now have really good Yokos so we'll see what happens.
oh yeah and stop hitting the limiter on your runs
My car is going to get some abuse on Sunday. I've been looking forward to this event for ages. I'm also using a car trailer so I've got no excuse not to let it "ave it"
25 front 30 rear for top speed & 1/4 IMHO
Then swap it round for handling.
You will nead to be able to steer the thing on the handling circuit, and a softer rear will help stop it sliding about from the back end.
If all else fails all the messing about with the pressure gague will piss off your competitors
Good luck
Good luck
Mc5506
Oct 5, 2015 09:57 PM
