Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
cosworth capri
Old Mar 20, 2006 | 04:59 PM
cossiegreg1's Avatar
cossiegreg1
Default cosworth capri
i posted in general discussion but i didnt seem to get any answers.i want to know what work is involved in fitting a 2wd cosworth engine into a capri.any info apreciated thanks
Old Mar 20, 2006 | 07:03 PM
Madbradz's Avatar
Madbradz
Not a lot from what I have been told... As im planning doing the same...
Should go in on pinto mounts... may need a modified sump... also may need a custom prop and just needs about 6 wires to wire it up
Old Mar 21, 2006 | 04:39 PM
cossiegreg1
cheers mate
Old Mar 21, 2006 | 04:54 PM
EssexBoyRacer's Avatar
EssexBoyRacer
there's been a couple done in old magazines.
not being a comon conversion (which is a shame!) I would guess there is some custom fabrication needed.
Old Mar 21, 2006 | 07:05 PM
costina's Avatar
costina
Live long and prosper!!
Easy but use a 2wd loom makes life easier
shortened prop about 1" needs to b taken out
2.8 i fuel tank and lsd (need to change ratio)
refabricate/ modifiy rear gearbox bracket
pinto eng mounts and use cossie sump
i used sierra cos rad and fans in my tina (bit of cutting req)
use a 4x4 cos s/steel exhaust cut and chop to fit (don't need much but will exit under axle)
hope this helps
Old Mar 22, 2006 | 04:33 PM
cossiegreg1
thanks alot. is there any mods needed to get the t5 box in?does the engine mounts need modifying or not ? it is a 1.6 at the mo
Old Apr 6, 2006 | 12:16 AM
cosworthcapri's Avatar
cosworthcapri
U can use standard pinto mounts.The tunnel has to be opened slightly to for the t5 box,by use of a hammer! easiest way to do it is to use a whole sierra.You also need a 2.8 injection tank with external pump.You can also use the standard 1.6 prop,although i have heard they need beefing up as they can break,i dont know yet as i havnt tried my car yet. The only problem i encountered was the clutch cable,the releasearm is on he opposite side on a t5,i found one on e bay,i believe its a transit item,apparently graham goode does them.
Old Apr 12, 2006 | 08:08 PM
paul brace's Avatar
paul brace
Default cossie capri
cut away rad mounts and use cossie rad on fabricated brackets with escort chargecooler-intercooler sat behind it;fits purfect !!!
Old Apr 25, 2006 | 05:11 PM
cossiegreg1
well iv spoke to my dad and he is keen to make this project happen.any more info or tips much apreciated,my dad has had the capri for bout 15 years and at the moment it is just sitting in the garage , he just uses the xr4x4 which he has,all the time.because the capri is only a 1.6 he has no interest in driving it anymore,with me having the cosworth i have now pursuaded him to fit a yb in the capri to give it a new lease of life.then it will be fun again and he will look forward to driving it again .
Here's some pics of the capri (its on axle stands)
this is his XR4x4 2.0 dohc
Old Apr 25, 2006 | 11:15 PM
cosworthcapri
Looks a very good shell,go for it!
Old May 3, 2006 | 12:32 PM
Xindi's Avatar
Xindi
Hi,i'm new to this forum,but I saw this article. I've been building a Cossie Capri for about 11 years (yeah i know looong while ) Started with a 1.6 Laser shell,but needed alot of welding rust holes up, so ended up with a 2.8i shell in pretty good nick
Old May 3, 2006 | 07:02 PM
cosworthcapri
iv been doing mine for 3 years now! started as just an engine change,ended up being stripped back tp a bare shell.Never mind be worth the wait,i hope!
Old May 3, 2006 | 09:31 PM
tiptop's Avatar
tiptop
ive got 1 and can send some pictures if any 1 interested ,would put up pictures but not to good on computer thanks
Old May 4, 2006 | 12:06 AM
Xindi's Avatar
Xindi
yeah i'd love to see some of em What sort of brake setup you got? i'm only running 13" rims
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
