Vernier slipped!
Mar 20, 2006 | 02:40 PM
Vernier slipped!
The adjustable venier has slipped on the inlet side of my 4x4 cossie and has become very laggy
and the allen bolts where done up tight, is it just a case of loosening up the allen bolts and setting it back to zero or is it a case of re-timing it again?
Rand
May 18, 2006 | 02:51 PM
May 18, 2006 | 03:00 PM
safest thing would be to check the cam timing from scratch
May 20, 2006 | 08:25 PM
Do you have any pics of engine when ok?
Worth a try to see where is was if you can see.
May 21, 2006 | 01:48 PM
best be safe set it up from scratch as if fitting new cambelt
May 21, 2006 | 02:20 PM
is there no original witness marks on the pulley you can move it back to untill it can be redone later?
May 22, 2006 | 07:44 AM
There is original marks, you can see where it has slipped, its retarded about 5 degrees
May 23, 2006 | 12:02 AM
move it back,take plugs out and turn crank TWO full turns to check for valve/piston contact .
May 23, 2006 | 10:37 AM
Thanks gents I'll give a go later tonight, if I do get piston to valve contact is it best to re-time it from scratch?
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
Nov 1, 2015 06:53 PM
krypton
Sep 23, 2015 07:29 PM
liam-rst
Was It You?
Sep 5, 2015 06:38 AM
