symptoms for map sens failure?
Old Mar 19, 2006 | 07:14 PM
Tim's Avatar
Tim
Default symptoms for map sens failure?
What are they ie back fire etc ?
Tim
Old Mar 19, 2006 | 07:17 PM
le-claw's Avatar
le-claw
Black smoke like fuck, will run crap then stall.....plugs will be soaked.
Old Mar 19, 2006 | 07:18 PM
SPADGE's Avatar
SPADGE
Tim when 'loser Ant' fooked my 3 bar when i leant it to him my car was back firing like it had als Changed the 3 bar and all was well again
Old Mar 19, 2006 | 07:34 PM
dave cos4x4's Avatar
dave cos4x4
mine was barely running,lots of black smoke out the back.
Old Mar 19, 2006 | 07:36 PM
Tim's Avatar
Tim
mine seems to think it has als lol well sounds like it lol might be same as your spadge.
Old Mar 19, 2006 | 08:54 PM
graham c's Avatar
graham c
dose it do it as it comes on boost matey
Old Mar 19, 2006 | 08:56 PM
AlexF's Avatar
AlexF
Map goes...
lots of over fueling
only runs right flat out
Old Mar 19, 2006 | 09:31 PM
Rick's Avatar
Rick
test the voltage at idle and with engine stopped (ignition on)
Old Mar 19, 2006 | 09:32 PM
Jim Galbally's Avatar
Jim Galbally
wot rick says...
Old Mar 20, 2006 | 08:31 AM
Tim's Avatar
Tim
feels like i have a limiter at 5500 ish lol alMIGHTY BANGS AND NEARLY PUTS US THROUGH WINDOW LOL UPS caps lock lol afr is all to cok on idle also up n down lol
Old Mar 20, 2006 | 11:23 AM
Matt's Avatar
Matt
your technical advice from me to measure voltage sweep across boost/vac range from ecu pins gave what results then?
had a voltmeter taped to my dash many a time myself lol
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
