fault
Old Mar 19, 2006 | 06:43 PM
dangerbrian's Avatar
dangerbrian
Default fault
when i put my wipers on they go slow and the computer on the dash say all doors are open the indicator on the clocks is on but very dim and both fog light switches flicker can any 1 help cheers bri
Old Mar 20, 2006 | 06:17 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Sounds like a bad earth to me mate, they can play terrible tricks on you, i just sorted one on my saph, i was puttin my lights on and if i put my indicator on at the same time my head light would indicate to , have you had anything of lately, i.e any wires or so, if you have go back round them and give them a good clean
Old Mar 21, 2006 | 07:10 PM
dangerbrian
the only thing ive fitted lately is a group a coil and also the indicators on the outside of the car come on but dim cheers m8
Old Mar 21, 2006 | 07:17 PM
Csm's Avatar
Csm
Yeah the earths are tottaly shite
Check all the major earths then check the connections to the rear lights as they are mega guilty of causing havoc ,i had the little switch lights for the foglights and heated screens light up and flicker and my rear lights were needin cleaned up and removed the corrossion ,greased them up also and all is good
tankybaby66
Feb 6, 2016 02:24 PM
DixieTheKid
Sep 14, 2015 09:04 PM
NC53
Sep 13, 2015 03:05 PM
Si B
Sep 12, 2015 06:49 AM
