Bleed valve.....
Old Mar 19, 2006 | 05:02 PM
Default Bleed valve.....
...got one off Stu a while ago to put in the actuator line to the amal...so i keep ecu control.....its like a tee piece but i forgot how to plumb it in I assume the 2 outlets opposite each other go in line and the bottom goes to atmosphere...is that right?
Old Mar 19, 2006 | 05:06 PM
Doug's Avatar
Doug
Seriously though Yes Phillis thats correct
Old Mar 19, 2006 | 05:08 PM
Are you laughing at my stupidity or using a bleed valve or both?
Nothing wrong with these according to Stu and Karl!!!Especially as i am retaining ECU control...it just saves you from fucking about with different sized jets!
Old Mar 19, 2006 | 05:12 PM
Doug's Avatar
Doug
Not laugthing at you using a valve mate just your forgetfullness
We all do it
Old Mar 19, 2006 | 05:14 PM
Just making sure incase i get 3bar boost
Old Mar 19, 2006 | 05:24 PM
Basky's Avatar
Basky
thought bleed valve were a no no on a cossie
Old Mar 19, 2006 | 05:31 PM
...a proper lockable one is more than ok mate.....Tuners dont genrally like em cause the customer can adjust his boost to destruction!!! Bare in mind if you retain a working amal valve the ECU still controls it.
Old Mar 19, 2006 | 05:36 PM
Basky's Avatar
Basky
so with the amal valve still connected you can fine tune the boost with the bleed valve basicly
TIFF's Avatar
TIFF
Chasing Radders
If people give them a fucking wide berth instead of "Tweeking" them,then they are fine once set up properly
Otherwise you get this
Old Mar 19, 2006 | 05:46 PM
Basky thats what i am hoping LOL....
Old Mar 19, 2006 | 06:26 PM
..PS this is on the ESCOS not the Saff!!!.....
Old Mar 19, 2006 | 06:32 PM
Billabong's Avatar
Billabong
Flippa, you shouldn't need a bleed valve on an EsCos, assuming you still have the Lektron valve (they work slightly differently to an amal valve as found on other Cossies).
Old Mar 19, 2006 | 06:36 PM
Billy it runs a normal valve
Old Mar 19, 2006 | 06:38 PM
Billabong's Avatar
Billabong
Why?
(are you running P8?)
Old Mar 19, 2006 | 08:09 PM
morto's Avatar
morto
alot of crap talked about bleed valves, i had one on for years with no bother .just as long as you understand them its been taken off now since the m.s.d. chip went in just cus stu saw it was anodised, so on his advice off it came.. brass lock ones or what you want, some tunners use them to get abetter power curve on the turbo.. i run a -34 so if you want to adjust the boost on that boy you need a crane if i ever do need to tho i use a electric tyre infalter plumed into the actuater and that moves the rod no bother
andy
Old Mar 19, 2006 | 11:23 PM
rapidcossie's Avatar
rapidcossie
bleed valves are fine.
had one on my car for ages when i first got it.
just make sure you have an accurate boost gauge or it can be trouble
Old Mar 19, 2006 | 11:32 PM
Billabong's Avatar
Billabong
Not arguing about bleed valves when used correctly, but a P8 ECU'd EsCos with Lektron valve does not need one if the boost map is mapped correctly. Maybe Phil's on L8 ......
Old Mar 20, 2006 | 11:14 AM
Billy no i am on P8 with anti lag but i dont run with the amal live....boost control is via jets size only
Old Mar 20, 2006 | 06:14 PM
Billabong's Avatar
Billabong
EDITED: because I can't read
Old Mar 20, 2006 | 06:51 PM
Disabled Account's Avatar
Disabled Account
Lektron valve - as supplied & fitted by Karl:
Old Mar 20, 2006 | 06:56 PM
Billabong's Avatar
Billabong
Doug, I know what one looks like lol, just wondering why Phil's using an amal valve instead.
EDIT: Doh, I'm sure Phil's explanation wasn't there when I replied - too many windows open and a long day
Old Mar 20, 2006 | 08:07 PM
morto's Avatar
morto
guys what the ..lectron valve ,? is it a kind of amal valve ? i now what the amal does ..
andy
Old Mar 20, 2006 | 08:23 PM
Billabong's Avatar
Billabong
EsCos Lektron valve is 2 port, and provides good boost control by the ECU (closed loop boost on P8 ECU).
An Amal valve is 3 port, and still controlled by the ECU, but often requires jetting to get the required boost levels.
Old Mar 20, 2006 | 09:22 PM
NEIL A's Avatar
NEIL A
Doug i nthe pic you put up was one hose removed at the time or is the one valve fitting just t'd into the actuator line to give a signal?
Old Mar 20, 2006 | 09:29 PM
Disabled Account
I dont know how it works
........I did not remove a hose. Maybe Karl or Stu will see this post and explain how it works.
Old Mar 20, 2006 | 09:42 PM
NEIL A's Avatar
NEIL A
Mmmmmm mibi this is what Bosch-Man was meaning about having an Lektron valve fitted but not running it live. Stu /Karl????
Old Mar 20, 2006 | 10:07 PM
Billabong's Avatar
Billabong
Phil says he's runing a jetted amal valve, not Lektron. The pipeless port on Doug's is the exhaust port (normally goes to the airbox IIRC). My old setup was like that.
Old Mar 20, 2006 | 10:19 PM
NEIL A's Avatar
NEIL A
So i take it the one that is used is just t'd into the hose fron the turbo to the actuator?
Chas
Oct 5, 2015 07:13 PM
kevin36
Sep 9, 2015 11:12 AM
markk
Sep 9, 2015 08:11 AM
kevin36
Sep 8, 2015 12:23 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
