petrol leak
Old Mar 19, 2006 | 12:43 PM
rapidcossie's Avatar
rapidcossie
Default petrol leak
just noticed i have a drip coming from around the fuel filter on my saf..
How is the pipe connected to the filter?
tried to tighten it but its solid.
take it there are copper washers of some sort in the banjo bolt that holds the pipe on.
is that wahst its called? banjo bolt lol
Old Mar 19, 2006 | 02:33 PM
foreigneRS's Avatar
foreigneRS
Testing the future
yep, banjo bolt. that may be tight, but that's better than a tight banjo string
they have copper washers (or ally) either side. replace them with new and it should sort it.
Old Mar 19, 2006 | 04:44 PM
toff's Avatar
toff
Default Re: petrol leak
an 18 and 17 to take it off , the washer might be fucked.
the leak canny be as bad as mine
Old Mar 19, 2006 | 11:10 PM
rapidcossie
cheers for the advice boys!
will get onto it the mora after work..
the washers avail in halfords etc?
Old Mar 20, 2006 | 07:53 AM
foreigneRS's Avatar
foreigneRS
Testing the future
yes. as i say, can either be copper or ally ones. just need the right size
Old Mar 20, 2006 | 03:52 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
sure you use enough petrol anyway euan so get it sorted
Old Mar 20, 2006 | 05:54 PM
rapidcossie
SORTED
new washers and fuel filter!...
Old Mar 21, 2006 | 02:36 PM
foreigneRS's Avatar
foreigneRS
Testing the future
Old Mar 22, 2006 | 07:24 PM
rapidcossie
after looking at the new filter and washers today just to check things over again it got me thinking?
should the filter be held in place by any kind bracket?
mines has a fair bit of movement in it.
wasnt any kind of braket already on the car but just a thought incase im missing something?
Old Mar 22, 2006 | 09:38 PM
nicksaph's Avatar
nicksaph
yes mate there should be a bracket holding the filter in place, held on with a 10mm bolt if i remember correctly
Old Mar 23, 2006 | 04:32 PM
rapidcossie
fook i must be missing mine then...
anyone any pics of what im looking for?
Old Mar 23, 2006 | 05:58 PM
nicksaph's Avatar
nicksaph
bit of a shite picture but you get the idea
http://cgi.ebay.co.uk/Ford-Sierra-RS...QQcmdZViewItem
Old Mar 23, 2006 | 11:23 PM
rapidcossie
cheers!!
timsrs
Nov 13, 2018 11:48 AM
Fudgey
21
Sep 30, 2015 06:19 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
talon1
Sep 15, 2015 10:27 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
