rounded of sump nut any suggestion how
get a file,file 2 flat sides onto it opposite each other,then use a spanner to remove it. or....get an easy out kit(screw extractor kit0 you drill into the bolt,then put an easy out in (its a cone shape with a reverse thread) then turn it anti clock wise whilst tapping the end of the easy out with a hammer to keep it seated et voila,bolt is removed
Hammer a slightly smaller socket on. Probably an imperial and then as you try and undo it tap the bolt with a hammer. It breaks the seal. Mechanic showed me that trick on my motocross bike when i fucked my sumpbolt. He got it undone in a few minutes
Best thing with sump bolts or any bolt thats too tight and feels like its gonna round off is to tighten it slightly first. This breaks the seal as well
Originally Posted by big_wig_074
i know it WILL work,but jesus! get a easy out kit and all done!no messing
you do know that these days theres a socket tool that will grip rounded nuts you can get from machine mart, as it turns it grips and bites and then your problem is solved
fuk all this welding shite and cutting atar shapes then chisel and file crap
1 tool and it does the job, think there about 20 quid and thats for the set too
think out of the box people
so many ways
ive taken so many rounded bolts off and i must say that all the above ways work.
dont knock the chisel idea, coz if he aint got a welder or the easy outs then its a way that will get him out of trouble quickly and its free.
if u can get a slightly smaller socket on then best to use a t bar and tap it while u try to turn it. this will help keep the socket on the nut and also help break the seal.
http://www.machinemart.co.uk/product...9&r=2073&g=111
next week ill show you tv's that work with w small box to automaticaly change the channel
very good ginge. give me a bolt that i cant get out with the tools in my garage and i'll give u the 20 quid!
any after uve shown me how to change the channel on the tv i'll show u how to line an engine up with a gearbox
Do machine mart do anything to help line engines up to gearboxes?????
Thought I had better make the point after all the suggestions about getting it out, do you have a replacement ready? Dont want to get it out and then realise you need to drive the car to get a new one
Originally Posted by 392B.H.P.SAFF
tried to tighten it firstv wont work put a 1/2 on it but as soon as u turn it it just turns
can i file it down to a 12mm
Bi-hexagonal
or Hexagonal
Use the Hexagonal one they dont slip as easily.
Monkey wrench first, if that doesnt work, hammer nad blunt chisel will almost certainly do it.
Get a BIT of heat on it too, will come out easier if its warm (but obviously dont blow torch it till the oil in the sump burns, lol)
but seriously, if you can get a smaller socket on the end, make sure it's only got 6 sides to it (as someone posted the pictuers of up top), put a fairly long extension on the end of it (to make sure you are keeping the socket properly onto the nut) and then get a big long bar (so you can apply even pressure without struggling and possibly slipping off the end if the nut decides to give up the ghost)
the other option, if you want to try it, is to use an impact drive to knock it off
you can get all sorts of tools to undo rounded nuts but they don't tend to work as well as they do on the telly
if you can find a stud extractor that might be worth trying too
one more thing
if you are worried about drilling through the bolt to get an easy out in there, don't worry, if you buy a new sump plug you can measure how deep you can get away with drilling before you go into the sump itself (not that you'd want to be doing that and getting swarf into the sump now do you, then you WOULD have to change the sump just to be on the safe side)
and one final thought, try using an impact socket on the nut as they have thicker sidewalls and have less chance of cracking
ginge, if its them draper 3 taper bit sockets, than its all well and good like, but the c*nts dont work unless you place it vertically on the stud.
as in i paid £20 for one to remove the seat bolt that the head sheared off, from under the car.
place shiney new stud remover under the car, and it does fuck all as theis thing called gravity pulls the taper bits away from the fookin stud
ended up drilling the fukka out
