stainless bolts!
im gona strip the underside of my s2 and i wana replace all the bolts etc,is there anywhere that sells the bolts as a job lot,if you get what i mean?or just anywhere that sells the bolts!...thanks...
Oh god not again
Please DO NOT put any stainless bolts on any load bearing parts - they are nowhere near strong enough.
You'd be better off tying it all together with string
Use only the properly rated bolts please, and if you want it to look bling then just get them plated.
aahhh i see,i thought stainless bolts were better than standard 1's.in that case is it possible to still get all of the standard ones,as i know ford dont do all the bolts anymore.
im not bothered about the bling i just thought people used em cus they were better!
Dave Y-refurb bolts.where would i get that done?
An M6 or M8 bolt will be the same wherever you get them from.
Ford don't actually make any of them
Just find them your local hardware shop
Source them from Fords and you'll pay 25p for the bolt and £2.50 for the bag it comes in
i just want a clean car,very clean!thats why ive spent all day strippin it out,and lying underneath the car stripping all the underseal off!
i just wana repalce the bolts that are passed it,so im gona collect all the bolts i take off in tubs and go round ALL the places i can think os and try to match em up!
Why get bolts re-furbed?? If it even exists??
A Grade 8.8 bolt [which I think they all will be] is a grade 8.8 bolt....just get down your local hardware store with all your old ones and ask them to swop them for a new set
Job done
[As Tony says] if you want them to look bling then get plated versions
Job done
Originally Posted by dave_y
re-furbed - i meant cleaned up, get all the shite off them so they look 'nicer'
Originally Posted by NUTS RuS
John, you'd be surprised what people send us for sandblasting and re-plating
Still if it makes them happy then we'll do it
Surely that costs more than buying new
