Unfinished project - 2.0zvh ERST 1990
Old Mar 18, 2006 | 07:28 PM
Moose 130's Avatar
Moose 130
Default Unfinished project - 2.0zvh ERST 1990
Don't know when I'll get time to finish, and I'm getting tired of pushing it in and out of work and generally looking at it, so it might as well move on (assuming I get a sensible price.....
1990/G Escort turbo, mercury grey
NEW 2.0 short block from Ford
XR2i cylinder head with new exhaust valves, aftermarket cam and heavy duel springs, head mildly ported.
XR2i manifold modified to run Cosworth EFI, throttle body and fuel rail
Cosworth yellow injectors, map sensor etc etc
ZOO distributor
L6 ECU with std chip
4 puck clutch - new
bespoke breather pot and silicone hoses.
Pipercross filter
Duel Cosworth intercoolers
SS exhaust system
Escos front brakes - new discs and pads
Sapph rears new discs, pads, braided hoses
ABS removed
Poly bushes all over
17 inch alloys with good tyres
bumper cut for the intercoolers
excellent interior
Only welding needed, two small patches at the end of both sills and a small plate on the NS flont floor joint.
Needs some paint across the front and down both sides.
Windscreen needs refitting (supplied)
loom needs soldering into the car to work as far as I know.
probably owes over £3000
Lowest price is £2500.
if you have nothing constructive to say, please say nothing.
Pics will follow when the weather is better and I'm at work!
Might break if it'll make more money!
wowk
Mar 30, 2021 07:49 PM
gambo08
Feb 4, 2016 10:49 PM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
