High Boost Low Boost
Mar 18, 2006 | 07:19 PM
want to get the car set up to run 16psi, but dont want to run it all the time, basically how do i get a high/low boost set up in???
want it to run a std 8 on low boost, but have the 16 on tap to go and have some fun
cheers
dave
Mar 18, 2006 | 07:20 PM
Mar 18, 2006 | 10:03 PM
dammit wheres that amal valve i took off my car
Mar 19, 2006 | 07:43 AM
cheers dude its really that easy!!
want that to have some fun
Mar 19, 2006 | 09:52 AM
Quote:
you cant use a frst one, you need an escort item
Mar 19, 2006 | 01:08 PM
Remember your fuelling will have to be set up for high boost, which means over fuelling at low boost. Other way round and it will blow up.
Not really a good situation any way you look at it.
Mar 20, 2006 | 05:07 PM
booked into engine advantages for a tune up,
can run high/low boost on a frst amal valve so will have to see what happens when i get there
roll on 11th april
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Tank Mike
Sep 26, 2015 08:07 AM
