Which way do you turn idle speed screw?
Old Jul 28, 2004 | 09:00 PM
kevsrs's Avatar
kevsrs
Default Which way do you turn idle speed screw?
It's an S2 and wondered which way you turn the screw for more revs and less revs?
Old Jul 28, 2004 | 09:02 PM
slowpoke's Avatar
slowpoke
turn it one way and see what it does lol
when i adjusted mine you sposed to rev it to around 2500 and then let it settle i think
Old Jul 28, 2004 | 09:03 PM
Stu @ M Developments's Avatar
PassionFords Creator
clockwise = less
Old Jul 28, 2004 | 09:25 PM
kevsrs's Avatar
kevsrs
I knew someone would say that
Just wanted to check cos you need to turn it quite a bit for much to happen
Old Jul 28, 2004 | 09:39 PM
slowpoke's Avatar
slowpoke
yeah i noticed that too i thought a little turn would change things but you really have to give it some lol
Old Jul 28, 2004 | 09:48 PM
Jim Galbally's Avatar
Jim Galbally
as per stu...
think of it as erm... a screw... lol
its like a bleed valve... theres a hole near the end of the thread of the screw and so if you losen the screw it moves out more letting more air bypass the throttle hence revs increase (same affect as openeing the throttle a bit)
Old Jul 28, 2004 | 10:00 PM
kevsrs's Avatar
kevsrs
Originally Posted by Jim Galbally
as per stu...
cheers jim
TPM961
Jan 15, 2018 10:50 AM
Chas
Oct 5, 2015 07:13 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
routemaster
Sep 7, 2015 05:27 PM
hopper350
Sep 4, 2015 12:53 AM
