cosworth capri
hi my dad has a mint capri 1.6 and iv been gettin on to him to put a cossie in it,i was just wondeing what work is involved? any info appreciated thanks
Originally Posted by slowpoke
you mean rusties cossie capri rad ?
matt
matt
It was in the first Daddy Thrash with Performance Ford mag if thats any help
Not got any issues with me at the moment
Relocate battery to boot - gives a lot more space, but not strictly required depending on intercooler / radiator choice
Remove original battery tray and radiator mounts to allow cossie rad and escort chargecooler (brackets of both slightly modded) to fit nicely
Use 1.6 / 2 litre engine crossmember and engine mounts with 50mm rubbers
Modify a 1.8 sierra gearbox crossmember, using the standard T5 aluminium spacer and rubber mount
Shorten front half of 1.6 / 2.0 propshaft (don’t use 2.8) by 30mm
Use 1.6 axle (standard crownwheel, pinion, and halfshafts) – takes 300 brake OK
Build a 2.8 lsd into the axle if available
Uprate suspension, brakes to suit use
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Adam Graham
Sep 6, 2015 06:04 AM
not 2 sure but i think the cossie yb fits in2 a pito crossmember.
