Swirl Pots......Yes or No
Old Mar 17, 2006 | 06:03 PM
S2Dan's Avatar
S2Dan
Default Swirl Pots......Yes or No
Been contemplating the idea and not sure what to make of them. Apart from being an extra shinny accessory, are they really an extra worth having.
I understand the principals of how a swirl pot works, and in theory it sounds to be a good extra. But from my understanding, doesn’t the thermostat housing act like a sort of swirl pot, by extracting air back into the headertank.
Just wondered what peoples views were on them, are they worth putting on or are they just really a extra shiny show piece.
If they are considered to be a good extra, do you guys a) blank of the top of the thermostat housing and run the one hose from the header tank to the top of the swirl pot, or b) providing the headertank has two breather ports, run one hose to the top of the thermostat housing and the other hose to the top of the swirl pot. What’s the better method!!!
CheeRS guys
Old Mar 17, 2006 | 06:07 PM
T28 RST's Avatar
T28 RST
Ok then
I got mine coz it looked nice
Old Mar 17, 2006 | 06:27 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Same here ! Got a Spec-R one which looks the danglies. Just bought a Spec-R oil breather now as well..........
Old Mar 17, 2006 | 06:34 PM
Rick's Avatar
Rick
Ur understanding is right. The Stat housing is a swirl pot - and works REALLY well as std. Swirl pots look stupid - two next to each other
Oil Seperators on the other hand, are defo worth it.
Old Mar 17, 2006 | 06:44 PM
S2Dan's Avatar
S2Dan
I agree, they do look the nutz, the more bling the better
How have you guys fitted them tho, with just one hose in top of swirl pot, or with two hoses, one in the top of thermostat and one in top of swirl pot.
Old Mar 17, 2006 | 06:47 PM
John Laverick's Avatar
John Laverick
Waste of money as Rick says....if you want your engine bay full of useless metal then go for it
Old Mar 17, 2006 | 07:02 PM
Rick's Avatar
Rick
cos 2 hoses makes so much sense
Old Mar 17, 2006 | 07:06 PM
S2Dan's Avatar
S2Dan
Really it's only down to personal choice then with these. So to sum them up in a nut shell, they don't make a blind bit of difference, as the thermostat housing takes care of the job. Just if ya fancy a bit more bling, then these are another extra shiny bit.
Old Mar 17, 2006 | 07:18 PM
DanRSturbo's Avatar
DanRSturbo
Only really good for the bling effect I'm afriad.
Old Mar 17, 2006 | 07:28 PM
T28 RST's Avatar
T28 RST
Ok then
Thats all i got it for
Old Mar 17, 2006 | 07:30 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
..spec-r the daddies
Old Mar 17, 2006 | 08:02 PM
Rick's Avatar
Rick
spend ur money on something else! Gear lever bushes, engine mounts, rust killer....
Old Mar 19, 2006 | 10:16 AM
EssexMikeSi's Avatar
EssexMikeSi
ive got one for mine mate and im gona fit the thermostat housing area part from a 1.4 mk4 esc wen i get to that stage of the engine build coz they dont have the swirl pot built into them
Old Mar 19, 2006 | 11:40 AM
Oranoco's Avatar
Oranoco
Seems like a lot of grief for something you don't need. They do look nice though
Old Mar 19, 2006 | 05:44 PM
NUTS RuS's Avatar
NUTS RuS
Neons next
timsrs
Nov 13, 2018 11:48 AM
mk1turboestate
Dec 2, 2015 08:31 PM
Nov 1, 2015 06:53 PM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
