Neither does mine, but I have an open breather system. Chances are your mate has a blocked breather pipe or something like that, worst case is it is knackered.
every one ive had or worked on has either died or ran really rough as a rule i walk away from 1s that dont and they've still got original breather system
mine used to die if you took the cap of till the engine went bang. (due to well over 30psi of boost)
now ive rebuilt the engine it runs fine if you take off the cap. does this meen i've got somthing wrong somewhere?
got to take the head off to sort out a leaky core plug thing so i'll check it all out when i do that.
i'm just happy it runs. i didn't know a thing about building engines till i built this one.
They're only about £6 or £7 last time I bought one. Don't bother trying to open up the existing one and clean it out...more hassle than it's worth. Replace it, nice cheap and easy
Also serviceable items anyway which a lot of people don't realise, 40,000miles i believe, they start to break down over time and don't actually do the job theyre meant to.
