Wire rung
what does this mean?its just annoying me when i read it in specs and i dnt know what it means.plus if i know what it is then i can start wanting it to!
lol!
Pretty sure this is only for cars with piston liners, they basically are "wire rung" (wire wrapped) around the outside of the liners to strengthen them.
If thats wrong no doubt someone will come and shoot me down
Wire ringing a block;
This process is carried out by cutting a circle around each of the cylinders on the face of the block...wire is then fitted into the cut out leaving part of the wire higher than the block surface.
Theese wire(rings) then bite into the headgasket providing additional clamping force when the head and bottom end are torqued together.
Originally Posted by safechav
Originally Posted by Christian and Beccy
30psi peak on a 1600 RST with Standard Ford Head Gasket and Bolts.
Who needs Wire-ringing??!!
Seemed OK as it approached 170mph.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
