Will changing to Poly Bushes give me a harsh ride??
Don't like my setup at the mo, this is down to crap springs IMO anyway
I have bought some koni adjustables and will be using Eibach springs
I do have some poly bushes to fit as well, but will this make it just as bad as it is now?
Hate the harsh ride 'cos roads where I live ain't too sharp and not exactly flat PMSL
Feels like hitting a pot hole every time I hit a slight bump and really fooking annoys me
Am I doing the right thing by fitting the poly bushes or should I get a complete set of new standard ones?
Originally Posted by J871yhk
konis are hard...
Got spax adjustables right now and was told koni should be the better shock of the two!
Told this by a respectable trader on here too
Anyway, the springs I have right now are like -30000000mm and stupidly low!!
Eibach are higher in the norm, would this comensate?
i dont have polly bushes but the konis give a very 'defined'
ride maybe its because the car is VERY low (at the front anyway) and the konis have to be set to 'hard' to avoid the wheels twatting up into the arches!
in my experience, polybushes will not give you a harsh ride - norfolks shitty roads will
Norfolk Council are proper Pikies I can tell ya!!
what i meant was the fact that my car is so low means i have to have the konis on hard.. that therefore makes the ride a little harsh.. i had higher springs on then i guess it could be set a little softer.. but at the expense of handling i expect.
CheeRS
Phil
CheeRS
Phil
my mate has koni's and poly bushes all round on his S2. his is quite a comfy ride even tho it is low to the ground. & our B roads in lincs can't be much better than yours!
handles pretty well too for a saloon car!!
also makes me PMSL when everyone with an RST sets theres no rock solid and thinks itl improve the handling.
make it worse on the road if anything, esp if you harden up the fronts loads, understeeeeeer
James, fitting bushes to the car will not make the ride harder, but may transfer more road noise. The springs and dampers are in control of the "hardness". This is why you have ADJUSTABLE dampers, set them to full soft you twat if you want the ride to be more comfortable
. I cannot believe how stupid you are at times
(although I am beginning to
Mike, they are on FULL soft at the moment you twat
Springs are way too fucking low anyway, camber of that thing is unreal
So more noise, who cares, in my car you struggle to hear eachother when talking, hence the damn stereo install I now have, drown it all out
Cheers for your input Mike
Has put my mind at ease LOL
What about if we both bring handbags to the next meet like Christian did on Tueday
and have a
contest!!
contest!!
Keep it hard you
Want to set my cossie to Hard but I think the coilovers are fucked, sat there for about 45 minutes turning the adjuster and never reached the end
!!Want to set my cossie to Hard but I think the coilovers are fucked, sat there for about 45 minutes turning the adjuster and never reached the end
Originally Posted by Itsmeagain
fookin RST uprated susp will, its horrid in my experience, uprated cossie stuff is often fine, but RST stuff is fookin well shitty ride
I ran my konis on full soft on my rst everywhere but the track.
RST suspension is just shite.PERIOD
Paul.
Adam Graham
Sep 6, 2015 06:04 AM
