Excessive heat
Ive noticed some discolouring under the bonnet, the throttle cable looks like its starting to melt
and the bonnet is a darker shade of red
Apart from laging the manifold how can i stop this
Originally Posted by gus
i had some heat probs with my manifold, so i had it ceramic coated inside and out
also had a small heat shield made to go in front of spark plug
l
also used bonnet lifters
l
engine looks like a nice bit of kit I've found that life I needed.. It's HERE!!
t28 , have you got 3 bat map sensor , im asking as i see your using magnecor leads, ive heard that they can cause rf feedback , and lead to map sensor failure ?
yours been ok ?
yours been ok ?
yours been ok ?
yours been ok ?
Cos500
Sep 16, 2015 09:50 PM
cossie09
Sep 10, 2015 06:56 PM
