2x T34s .48/.63 ALS 247shaft .More added!
For sale, good low mileage T34 ready to fit 2wd manifold, run on low boost 16PSI only,Quick spool up-low lag, just needs water pipes to complete. Offers around £420.
T34 with.63 ex housing, ALS 247 MARAM shaft and machined quick release bolt exhaust housing, no water pipes, -34actuator, 34mm restrictor available too. All ready to fit 4x4 manifold. I really dont want to sell this turbo
, I would prefer to shift my other stuff first but needs must, so offers now over £850
Also;
.75 over crank and alloy front engine cover and 2wd flywheel
2wd clutch (AP fast road clutch) some use, still good use yet
2wd fuel rail and regulator £30 PROV SOLD
2wd sump£40
pair of alloy cosworth engine mount arms £10
2wd sump oil pick up pipe
set of 4x std Cosworth pistons and con-rods £££offers
leather interior OK condition, worn and repaired drivers seat bolster£330
Solid top mounts for front of cosworth £50 the pair SOLD
Also;
2wd sump£40
RichardPON, yeah I got your PM mate, Im really wanting your engine now, just need to shift my T34 .48 turbo
Should have bought it with the shell tut,
. I still have your wheels too, maybe do you a deal for the engine wheels and tyres??
"3dr Wixsy" I have to sell my T34 with .48 first, if I dont sell that in April then I will HAVE to sell my ALS turbo which i REALLY REALLY dont want to do. I have had several offers now and they have reached nearly £850, but you were first to reply and WILL get first refusal. Apologies for not PMing you, they are flying in and out of my message boxs, but my .48 MUST be sold first ASAP.
I see by reading thru your for sal;e thread that you are thinking of buying Richards Engine. Well how about a deal for your turbo and a few odds and sods or whatever for a supposedly rebuilt stage 1 complete engine, turbo, ex manifold, l6 chipped ecu, etc absolutely ready to run.Can be driven, good oil pressure, no rattles, smoke or anything like that from cold. Runs faultlessly. Omly getting rid cos im either going rallying or building a monster engine for my 3dr. Only want £1500 ono for absolutely ready to run lump, just a thought, nothing missing AT ALL, regards Tony
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
