Alpha/Weber ECU useage?
Old Mar 13, 2006 | 10:54 AM
Escort-Ian's Avatar
Escort-Ian
Default Alpha/Weber ECU useage?
currently running a 2 litre zetec on bodies mapped with an Alpha/Weber ecu (fully 3d mappable etc) and was wondering if this ecu would be able to map a turbo application on the same engine?
any ideas?
if not, what sort of prices are the megasquirt kits?
thanks
Old Mar 13, 2006 | 11:57 AM
AlexF's Avatar
AlexF
IIRC you can use them on turbos...
best to ring webcon
Alex
Old Mar 13, 2006 | 12:05 PM
Escort-Ian's Avatar
Escort-Ian
cheers alex!
also...
what are the benefits of having individual inlets (ie throttle body inlet) on a turbo'd car rather than the conventional RST style inlet manifold?
it has the fuel rail etc already on, and therefore all the wiring for the ecu, would it just be a case of getting some sort of custom inlet made up to go over the manifold??
and does anyone actually understand what i'm saying or am i just thinking complete balls?!
Old Mar 13, 2006 | 12:46 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
similar to what im doing mate.
depends on how much power you want really but should be pretty beefy
as you got em, you may as well use em
you will just need a custom inlet plenum that connects to the air filter.
Old Mar 13, 2006 | 12:58 PM
AlexF's Avatar
AlexF
There is little real benifit...
infact it makes it more complicated!!!!
Running one TB is easy as theres nothing to set up. Trying to tune individual TBs so that each cylinder can be fed the same amount of air is hard. For a start they are in a closed chamber!
Could you run a std inlet manifold?
Alex
Old Mar 13, 2006 | 12:59 PM
Escort-Ian's Avatar
Escort-Ian
Alex
yeah i could, and after a bit of research seems the more logical (cheaper) step really, was just thinking of ways to use what i have already
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
